Saltar al contenido principal
Introducción
Use this guide to remove or replace the back cover of the LG G3 (B855).
  1. LG G3 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 LG G3 Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Back Cover Replacement: paso 2, imagen 1 de 2 LG G3 Back Cover Replacement: paso 2, imagen 2 de 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
Conclusión
4 personas más completaron esta guía.
Dominik Schnabelrauch
Miembro Desde 23/11/16
145,804 Reputación
596 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
146 Miembros
16,105 Guías creadas
Un comentario
Really. Was this necessary
James Beam - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 32
Todo El Tiempo: 4,217
