Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
LCD Screen Replacement
Qué necesitas
    1. LCD Screen  Replacement, Battery Door: paso 1, imagen 1 de 1
      • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
      Pregunta a FixBot
      Agregar Comentario
    2. LCD Screen  Replacement: paso 2, imagen 1 de 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
      Pregunta a FixBot
      Agregar Comentario
    3. LCD Screen  Replacement: paso 3, imagen 1 de 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
      Pregunta a FixBot
      Agregar Comentario
    4. LCD Screen  Replacement: paso 4, imagen 1 de 2 LCD Screen  Replacement: paso 4, imagen 2 de 2
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
      • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
      Pregunta a FixBot
      Agregar Comentario
    5. LCD Screen  Replacement: paso 5, imagen 1 de 1
      • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    6. LCD Screen  Replacement: paso 6, imagen 1 de 3 LCD Screen  Replacement: paso 6, imagen 2 de 3 LCD Screen  Replacement: paso 6, imagen 3 de 3
      • Use the plastic opening tool to pry the back and front casings of the camera apart.
      • Once pried apart use your hands to pull off the back plate of the camera.
      • You will need to apply a little bit of force to remove the back plate.
      Pregunta a FixBot
      Agregar Comentario
    7. LCD Screen  Replacement: paso 7, imagen 1 de 3 LCD Screen  Replacement: paso 7, imagen 2 de 3 LCD Screen  Replacement: paso 7, imagen 3 de 3
      • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
      Pregunta a FixBot
      Agregar Comentario
    1. LCD Screen  Replacement, LCD Screen: paso 8, imagen 1 de 3 LCD Screen  Replacement, LCD Screen: paso 8, imagen 2 de 3 LCD Screen  Replacement, LCD Screen: paso 8, imagen 3 de 3
      • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 3-2, Sullivan Spring 2016 Miembro de USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
Miembros de 4
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 990
