Saltar al contenido principal
Jura Impressa S model Water Reservoir Seal Replacement
Qué necesitas
  1. Jura Impressa S model Water Reservoir Seal Replacement, Water Reservoir Seal: paso 1, imagen 1 de 3 Jura Impressa S model Water Reservoir Seal Replacement, Water Reservoir Seal: paso 1, imagen 2 de 3 Jura Impressa S model Water Reservoir Seal Replacement, Water Reservoir Seal: paso 1, imagen 3 de 3
    • Remove the water reservoir.
    • Turn the Jura on its side to have access to the bottom plate
    • The water connector is protected by a plastic cover, which is secured by two plastic rivets.
    • Use some pliers and squeeze the rivets tightly and push them up until they release.
    • Carefully pry up the plastic cover.
    • Insert the new gasket with the flat side facing up.
    • Give some food-proof lubricant to the new seal and replace it.
Conclusión
To reassemble your device, follow these steps in reverse order
Un agradecimiento especial a estos traductores:
de en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
VauWeh
Miembro Desde 10/19/15
202,857 Reputación
246 Guías creadas
Equipo
Repair is War on Entropy Miembro de Repair is War on Entropy
Community
25 Miembros
1,110 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 658
