Saltar al contenido principal
Jura Impressa S model front cover
Qué necesitas
  1. Jura Impressa S model front cover, How to open a Jura Impressa S model cover: paso 1, imagen 1 de 2 Jura Impressa S model front cover, How to open a Jura Impressa S model cover: paso 1, imagen 2 de 2
    • Always remove the power cord from the wall outlet.
    • Lift out the coffee tray
    • Remove the lid sealing the coffee bean container
    • Remove all of the coffee beans you can possibly remove.
    • Pull the adjuster of the coffee bean grinder straight up
    • Remove the four T15 Torx screws
  2. Jura Impressa S model front cover: paso 2, imagen 1 de 2 Jura Impressa S model front cover: paso 2, imagen 2 de 2
    • Remove the cup heat plate.
    • It can be opened like a book.
    • Below the cup heat plate there are three more T15 Torx screws. Remove them.
  3. Jura Impressa S model front cover: paso 3, imagen 1 de 1
    • The top cover is now free. Lift ´er up and set ´er aside.
  4. Jura Impressa S model front cover, Jura Impressa S model front cover: paso 4, imagen 1 de 2 Jura Impressa S model front cover, Jura Impressa S model front cover: paso 4, imagen 2 de 2
    • Remove the knob for the steam valve by simply pulling it off.
    • The front cover is secured with a Torx T15 screw. Remove it.
  5. Jura Impressa S model front cover: paso 5, imagen 1 de 1
    • Now the front cover can be opened like a door for a few inches. The hinge is on the left.
  6. Jura Impressa S model front cover: paso 6, imagen 1 de 1
    • Various hoses hinder the further opening of the front cover. You need to remove the steam valve keypad from the cover.
    • Use a spudger to lift the two notches at the top of the front cover a bit to release the keypad at the top.
    • Lift the keypad upwards and pull it to the back. The steam pipe will slide out from its connection.
    • All hoses can remain connected.
  7. Jura Impressa S model front cover: paso 7, imagen 1 de 1
    • Remove the silicone hose leading from the steam valve to the coffee spout. If it is secured with a cable tie which must be removed first.
    • The front cover is now free and can be opened.
Conclusión
To reassemble your device, follow these instructions in reverse order
Un agradecimiento especial a estos traductores:
de en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
VauWeh
Miembro Desde 10/19/15
203,382 Reputación
246 Guías creadas
Equipo
Repair is War on Entropy Miembro de Repair is War on Entropy
Community
25 Miembros
1,121 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 15
Todo El Tiempo: 702
