Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
JD Razor 2000 Back Wheel Replacement
Qué necesitas
    1. JD Razor 2000 Back Wheel Replacement, Unscrewing the Axle Bolt: paso 1, imagen 1 de 2 JD Razor 2000 Back Wheel Replacement, Unscrewing the Axle Bolt: paso 1, imagen 2 de 2
      • Facing the wheelie bar as shown, place your left thumb on the bolt located on the left side of the back wheel and place the Allen wrench into the screw on the right side of the back wheel.
      • Using the wrench, slowly unscrew the bolt while applying constant pressure from the left side.
      Pregunta a FixBot
      Agregar Comentario
    2. JD Razor 2000 Back Wheel Replacement, Removing the Bolt and Bearing: paso 2, imagen 1 de 2 JD Razor 2000 Back Wheel Replacement, Removing the Bolt and Bearing: paso 2, imagen 2 de 2
      • Remove the bolt from the right side and the bearing from the left.
      Pregunta a FixBot
      Agregar Comentario
    3. JD Razor 2000 Back Wheel Replacement, Removing the Wheel: paso 3, imagen 1 de 1
      • Turn the JD Razor 2000 on its side as shown. Slowly remove the back wheel by pulling it out at a perpendicular angle to the scooter base.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 4-46, Amido Fall 2014 Miembro de Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
Miembros de 4
16 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 40
Todo El Tiempo: 1,348
