Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
JBL Pulse LED Light Replacement
Qué necesitas
    1. JBL Pulse LED Light Replacement, Button Board: paso 1, imagen 1 de 1
      • Use a plastic opening tool to pry around the edges of the circular rubber panel.
      Pregunta a FixBot
      Agregar Comentario
    2. JBL Pulse LED Light Replacement: paso 2, imagen 1 de 1
      • Once the edges are loose, pull off the rubber button panel completely.
      • New adhesive will have to be applied when reassembling.
      Pregunta a FixBot
      Agregar Comentario
    3. JBL Pulse LED Light Replacement: paso 3, imagen 1 de 1
      • Use your plastic opening tool to pry the button board loose by lifting the edges.
      Pregunta a FixBot
      Agregar Comentario
    4. JBL Pulse LED Light Replacement: paso 4, imagen 1 de 1
      • Lift the button board, exposing the attached cable.
      Pregunta a FixBot
      Agregar Comentario
    5. JBL Pulse LED Light Replacement: paso 5, imagen 1 de 1
      • Pull black piece on top of socket away from board to loosen, then detach the cable.
      Pregunta a FixBot
      Agregar Comentario
    1. JBL Pulse LED Light Replacement, Outer Casing: paso 6, imagen 1 de 3 JBL Pulse LED Light Replacement, Outer Casing: paso 6, imagen 2 de 3 JBL Pulse LED Light Replacement, Outer Casing: paso 6, imagen 3 de 3
      • Take out the four 9mm black PH0 screws from the top and bottom of the device.
      • Pull off cap by hand.
      • The outer casing can now be removed.
      Pregunta a FixBot
      Agregar Comentario
    1. JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: paso 7, imagen 1 de 2 JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: paso 7, imagen 2 de 2
      • Remove the tape around the cables on the top of the device.
      • Remove the cables by lifting up on the black bracket and then pulling the cable out.
      Pregunta a FixBot
      Agregar Comentario
    1. JBL Pulse LED Light Replacement, LED Light: paso 8, imagen 1 de 1
      • Pry off LED light panel using a metal spudger.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 18-6, Blackwell Fall 2016 Miembro de USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
Miembros de 3
28 Guías creadas
1Guía Comentario
Were do I buy a Replacement led strip?
Jalen6988 - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 3,831
