Qué necesitas
Flip the projector right-side up and turn it so that the back ports are facing you.
Remove the 7 mm metallic screws using the flat-head screwdriver.
Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
Once the main board has been removed, carefully lift the fans upward. Make sure no cables are tangled in the process.
Una persona más ha completado esta guía.
