Saltar al contenido principal
Huawei Watch GT 2 (42 mm) Motherboard Replacement
Qué necesitas
  1. Huawei Watch GT 2 (42 mm) Motherboard Replacement, Remove the watch band: paso 1, imagen 1 de 1
    • Before starting the repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Huawei Watch GT 2 (42 mm) Motherboard Replacement, Unfasten the screws: paso 2, imagen 1 de 1
    • Use a T2 Torx screwdriver to remove the four 3.6 mm screws securing the back cover assembly.
  3. Huawei Watch GT 2 (42 mm) Motherboard Replacement, Pry up the back cover assembly: paso 3, imagen 1 de 3 Huawei Watch GT 2 (42 mm) Motherboard Replacement, Pry up the back cover assembly: paso 3, imagen 2 de 3 Huawei Watch GT 2 (42 mm) Motherboard Replacement, Pry up the back cover assembly: paso 3, imagen 3 de 3
    • Insert an opening tool in the seam on the top edge between the back cover assembly and the watch case.
    • Use the opening tool to pry up the back cover assembly of your Huawei Watch GT 2 (42 mm).
    • Don't fully remove the back cover assembly just yet. It's still connected to the motherboard.
  4. Huawei Watch GT 2 (42 mm) Motherboard Replacement, Lift the back cover assembly: paso 4, imagen 1 de 2 Huawei Watch GT 2 (42 mm) Motherboard Replacement, Lift the back cover assembly: paso 4, imagen 2 de 2
    • Carefully swing the back cover assembly open to an upward position.
  5. Huawei Watch GT 2 (42 mm) Motherboard Replacement, Unhinge the metal shield: paso 5, imagen 1 de 2 Huawei Watch GT 2 (42 mm) Motherboard Replacement, Unhinge the metal shield: paso 5, imagen 2 de 2
    • The metal shield is held in place by a clip.
    • Insert an opening pick in the gap between the metal shield and the shield bracket on the motherboard.
    • Push the opening pick slightly downwards to unhinge the metal shield.
  6. Huawei Watch GT 2 (42 mm) Motherboard Replacement, Remove the metal shield: paso 6, imagen 1 de 1
    • Remove the metal shield.
  7. Huawei Watch GT 2 (42 mm) Motherboard Replacement, Disconnect the back cover assembly: paso 7, imagen 1 de 2 Huawei Watch GT 2 (42 mm) Motherboard Replacement, Disconnect the back cover assembly: paso 7, imagen 2 de 2
    • Use a spudger to disconnect the back cover assembly.
  8. Huawei Watch GT 2 (42 mm) Motherboard Replacement, Separate the back cover assembly: paso 8, imagen 1 de 1
    • Separate the back cover assembly from the watch case.
  9. Huawei Watch GT 2 (42 mm) Motherboard Replacement: paso 9, imagen 1 de 3 Huawei Watch GT 2 (42 mm) Motherboard Replacement: paso 9, imagen 2 de 3 Huawei Watch GT 2 (42 mm) Motherboard Replacement: paso 9, imagen 3 de 3
  10. Huawei Watch GT 2 (42 mm) Motherboard Replacement: paso 10, imagen 1 de 2 Huawei Watch GT 2 (42 mm) Motherboard Replacement: paso 10, imagen 2 de 2
    • Use the pointed end of a spudger to disconnect the display flex cable from the motherboard.
  11. Huawei Watch GT 2 (42 mm) Motherboard Replacement: paso 11, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the four 2.3 mm screws securing the motherboard.
  12. Huawei Watch GT 2 (42 mm) Motherboard Replacement: paso 12, imagen 1 de 2 Huawei Watch GT 2 (42 mm) Motherboard Replacement: paso 12, imagen 2 de 2
    • Use an opening pick to pry up the motherboard.
    • Remove the motherboard.
Conclusión
Adriana Zwink
Miembro Desde 12/18/19
56,498 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 119
19,522 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 1,339
