Saltar al contenido principal
Huawei P8 Lite Battery Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
Resumen del Video
  1. Huawei P8 Lite Battery Replacement, Remove  Back Cover and Loudspeaker: paso 1, imagen 1 de 2 Huawei P8 Lite Battery Replacement, Remove  Back Cover and Loudspeaker: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Spudger
    $2.99
    Comprar
    • Use the Spudger tool to get access to the loudspeaker. Locate where the headphone jack is, then move about one-inch to the right and begin to gently pry the back-cover off the phone with the flat end of the Spudger tool. Make sure to pry apart the entire perimeter of the back-cover to prevent bending/cracking of the plastic.
    • Tools used: Spudger tool (used as a wedge to pry off the back-cover and loudspeaker.)
  2. Huawei P8 Lite Battery Replacement: paso 2, imagen 1 de 1
    • Remove three silver Phillips 000 screws.
    • Remove four T5 Torx screws.
  3. Huawei P8 Lite Battery Replacement: paso 3, imagen 1 de 2 Huawei P8 Lite Battery Replacement: paso 3, imagen 2 de 2
    Spudger
    $2.99
    Comprar
    • Gently, use the flat end of the Spudger tool, or a metal opening tool to lift and remove the loudspeaker from the phone. The loudspeaker is the entire portion of the phone where the screws were extracted.
  4. Huawei P8 Lite Battery Replacement, Replace Battery: paso 4, imagen 1 de 1
    • Locate adhesive strip underneath the battery and grip with your thumb and forefinger. Slowly pull on the adhesive strip until it's off to release adhesive securing battery.
  5. Huawei P8 Lite Battery Replacement: paso 5, imagen 1 de 1
    Spudger
    $2.99
    Comprar
    • Insert the Spudger tool underneath the battery multiple times to separate the adhesive securing the battery. Be careful not to bend the battery and lift it from the phone frame.
    • Replace the adhesive and insert the replacement battery into the slot.
Conclusión
To reassemble your device, follow these steps in reverse order.
6 personas más completaron esta guía.
Equipo
Metro State, Team 1-2, Carpenter Spring 2016 Miembro de Metro State, Team 1-2, Carpenter Spring 2016
MSU-CARPENTER-S16S1G2
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 9,148
