Introducción
Use this guide to replace a broken rear glass on your Huawei P8 Lite (2017).
You’ll need replacement adhesive to reattach components when reassembling the device.
Qué necesitas
Heat an iOpener and apply it to the rear glass for two minutes.
Apply a suction cup to the rear glass, as close to the right edge as possible.
Pull up on the suction up with strong, steady force to create a gap.
Insert the tip of an opening pick into the gap between the rear glass and frame.
Slide the tip of the opening pick to the bottom right corner to cut the adhesive.
Leave it there to prevent the adhesive from resealing.
Open the P8 Lite by swinging the rear glass up from the left side, like the back cover of a book.
Place the rear glass on the top of the battery.
Use a Phillips #00 screwdriver to remove the 2.9 mm screw.
Use the tip of an opening pick to pry up and loosen the metal shield.
Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Compare your new rear glass to the original part. You may need to transfer the fingerprint sensor or remove adhesive backings from the new part before installing.
