Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Huawei P20 Pro Home Button and Fingerprint Sensor Replacement
Qué necesitas
  1. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Rear Glass Replacement: paso 1, imagen 1 de 1
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Huawei P20 Pro is of moderate strength, however a hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    Pregunta a FixBot
    Agregar Comentario
  2. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 2, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 2, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 2, imagen 3 de 3
    • If the phone's rear glass is cracked, a suction cup may not stick very well. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the rear glass close to the bottom edge of the phone.
    • Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
    • Insert an opening pick in the gap and slide it to the bottom right corner. Leave it there to prevent the adhesive from resealing.
    Pregunta a FixBot
    Agregar Comentario
  3. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 3, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 3, imagen 2 de 2
    • Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing.
    Pregunta a FixBot
    Agregar Comentario
  4. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 4, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 4, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 4, imagen 3 de 3
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick along the left edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner of the phone to prevent the adhesive from resealing.
    Pregunta a FixBot
    Agregar Comentario
  5. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 5, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 5, imagen 2 de 2
    • In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it.
    • Insert a fourth opening pick at the top left corner of the phone.
    • Slide the opening pick along the upper edge of the phone to cut the adhesive beneath the rear glass and leave it in the top right corner.
    Pregunta a FixBot
    Agregar Comentario
  6. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 6, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 6, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 6, imagen 3 de 3
    • Insert a fifth opening pick at the top right corner of the rear glass.
    • Slide the opening pick along the right edge of the phone to cut the remaining adhesive.
    • Don't open the phone all the way yet. The proximity sensor flex cable is still connected to the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  7. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 7, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 7, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 7, imagen 3 de 3
    • Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
    Pregunta a FixBot
    Agregar Comentario
  8. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 8, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 8, imagen 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable.
    Pregunta a FixBot
    Agregar Comentario
  9. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 9, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 9, imagen 2 de 2
    • Remove the rear glass.
    • Before installing fresh adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    Pregunta a FixBot
    Agregar Comentario
  10. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Motherboard Cover and NFC: paso 10, imagen 1 de 1
    • Remove the nine Phillips #00 screws (3.4 mm length).
    Pregunta a FixBot
    Agregar Comentario
  11. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 11, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 11, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 11, imagen 3 de 3
    • Insert an opening pick under the left side of the motherboard cover that includes the NFC.
    • Slide the opening pick towards the top left corner of the phone and twist it to pry the cover out of its plastic clamps.
    Pregunta a FixBot
    Agregar Comentario
  12. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 12, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 12, imagen 2 de 2
    • Repeat the previous process on the right side and twist the opening pick to pry up the motherboard cover.
    Pregunta a FixBot
    Agregar Comentario
  13. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 13, imagen 1 de 1
    • Remove the motherboard cover.
    Pregunta a FixBot
    Agregar Comentario
  14. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Battery Disconnect: paso 14, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Battery Disconnect: paso 14, imagen 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
    Pregunta a FixBot
    Agregar Comentario
  15. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Interconnect Cable with Charging Port: paso 15, imagen 1 de 1
    • Remove the five Phillips #00 screws (3.4 mm length).
    Pregunta a FixBot
    Agregar Comentario
  16. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 16, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 16, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 16, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use a pair of tweezers to disconnect the antenna cable.
    • Use a pair of tweezers to pull the antenna cable out of its routing.
    Pregunta a FixBot
    Agregar Comentario
  17. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 17, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 17, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 17, imagen 3 de 3
    • Slide an opening pick under the left side of the daughterboard cover and start to pry it up until you can get a good grip.
    • Remove the daughterboard cover.
    Pregunta a FixBot
    Agregar Comentario
  18. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 18, imagen 1 de 1
    • Remove the two Phillips #00 screws (3.4 mm length) on both sides of the USB C port.
    Pregunta a FixBot
    Agregar Comentario
  19. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 19, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 19, imagen 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the upper end of the interconnect and charging port flex cable from the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  20. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 20, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 20, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 20, imagen 3 de 3
    • Use the flat end of a spudger to pry up and disconnect the bottom end of the interconnect and charging port flex cable from the daughterboard.
    • Use a pair of tweezers to move the antenna cable out of the way.
    Pregunta a FixBot
    Agregar Comentario
  21. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 21, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 21, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 21, imagen 3 de 3
    • Use a pair of tweezers to pull the charging port out of its recess.
    • Remove the interconnect cable including the charging port.
    Pregunta a FixBot
    Agregar Comentario
  22. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Battery: paso 22, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Battery: paso 22, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Battery: paso 22, imagen 3 de 3
    • Use an iOpener to loosen the adhesive beneath the battery. Apply the iOpener on the display for at least two minutes.
    • In the following step, only apply the spudger in the areas marked in red, which is where the battery adhesive is located.
    • Avoid the orange area where the display flex cable is running.
    Pregunta a FixBot
    Agregar Comentario
  23. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 23, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 23, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 23, imagen 3 de 3
    • In case you have trouble to pry up the battery the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for about two minutes to help weaken the adhesive.
    • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert the flat end of a spudger at the top left corner of the battery and start to pry it up.
    • Work your way down the left side of the battery and loosen the adhesive with the spudger.
    Pregunta a FixBot
    Agregar Comentario
  24. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 24, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 24, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 24, imagen 3 de 3
    • Insert the spudger at the top right corner of the battery and start to pry it up.
    • Work your way down to the bottom end of the battery to loosen all the adhesive.
    Pregunta a FixBot
    Agregar Comentario
  25. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 25, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 25, imagen 2 de 2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard. Replace it with a new battery.
    • Before installing a new battery remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place for 5-10 seconds.
    Pregunta a FixBot
    Agregar Comentario
  26. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Screen: paso 26, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Screen: paso 26, imagen 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable at the bottom left of the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  27. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 27, imagen 1 de 1
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough on all sides. Follow the iOpener instructions to avoid overheating.
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    Pregunta a FixBot
    Agregar Comentario
  28. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 28, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 28, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 28, imagen 3 de 3
    • Once the screen is warm to the touch, apply a suction cup to the upper edge of the phone.
    • Pull the suction cup upwards and insert an opening pick in the gap between the display glass and the plastic bezel. Start to cut the adhesive by sliding the opening pick to the top left corner.
    • Make sure you get in the right gap between the display and the plastic bezel. Do not pry between the bezel and the midframe.
    Pregunta a FixBot
    Agregar Comentario
  29. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 29, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 29, imagen 2 de 2
    • Insert a second opening pick and slide it to the top right corner of the phone.
    • Leave the picks in their places to prevent the adhesive from resealing.
    Pregunta a FixBot
    Agregar Comentario
  30. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 30, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 30, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 30, imagen 3 de 3
    • Insert a third opening pick at the top right corner of the phone.
    • Slide the opening pick down to the bottom right corner to cut all the adhesive. Leave it at the bottom right corner to prevent the adhesive from resealing.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
    Pregunta a FixBot
    Agregar Comentario
  31. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 31, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 31, imagen 2 de 2
    • Insert a fourth opening pick at the bottom right corner.
    • Only slide the tip of the opening pick along the bottom edge of the phone to not damage the home button.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
    Pregunta a FixBot
    Agregar Comentario
  32. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 32, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 32, imagen 2 de 2
    • Insert a fifth opening pick and slide it along the left edge of the phone to cut the remaining adhesive.
    • Try not to remove the display all the way yet, the display cable is still threaded through the frame and adhered on the opposite side.
    Pregunta a FixBot
    Agregar Comentario
  33. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 33, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 33, imagen 2 de 2
    • Use a pair of tweezers to peel the display flex cable free from the frame.
    • Thread the display flex cable through the gap in the frame and remove the display.
    Pregunta a FixBot
    Agregar Comentario
  34. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Home button including the fingerprint sensor: paso 34, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement, Home button including the fingerprint sensor: paso 34, imagen 2 de 2
    • Use an opening pick to open the black flap of the home button ZIF connector.
    Pregunta a FixBot
    Agregar Comentario
  35. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 35, imagen 1 de 2 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 35, imagen 2 de 2
    • Use a pair of tweezers to gently pull the home button flex cable out of its ZIF connector.
    Pregunta a FixBot
    Agregar Comentario
  36. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 36, imagen 1 de 1
    Pregunta a FixBot
    Agregar Comentario
  37. Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 37, imagen 1 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 37, imagen 2 de 3 Huawei P20 Pro Home Button and Fingerprint Sensor Replacement: paso 37, imagen 3 de 3
    • Apply a spudger to the backside of the home button and push it out towards the front until it comes off the screen.
    • Carefully grab the home button and thread its flex cable through the gap in the screen.
    • Remove the home button.
    • Before installing a new display, it's important to remove all traces of the old adhesive from the frame, and clean the glued areas with isopropyl alcohol (>90%) and a lint-free cloth.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
The best way to re-apply the screen is with a sheet of custom-cut double-sided tape. Remove any old ahesive and apply the new tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
6 personas más completaron esta guía.
Dominik Schnabelrauch
Miembro Desde 11/23/16
259,250 Reputación
682 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 122
25,949 Guías creadas
11Guía Comentarios
Hello, is p20 fingerprint sensor same as p20 pro and can u switch them betwin models? Thanks for answer.
michi125125 - Contestar Compartir
Is it really needed to dissemble all the phone? The more I look at tutorial, the more it seems you can just unglue the screen (while it's still attached to the phone) and remove the fingerprint scanner. I'm I wrong?
Christo Bd - Contestar Compartir
Hi Christo,
the display cable of the Huawei P20 Pro is held in place by adhesive underneath the battery. Not removing the battery and loosening the adhesive underneath the cable will result in damage to the display and/or display cable when trying to lift the screen. At the same time the glued cable will hold the display in place and it won’t be possible to lift the display high enough to open the ZIF connector of the fingerprint without causing critical tension to the cable. However it can be possible to do it the way you were mentioning but this will require some experience with smartphone repairs and a good amount of instinctive feeling.
Dominik Schnabelrauch - Contestar Compartir
Leider ist mit beim Herausdrücken des Sensors der Metallrahmen mit herausgefallen. Diesen bekomme ich jetzt nicht mehr fest. Was mache ich denn jetzt? :(
Thorsten - Contestar Compartir
Hi Thorsten, Ich vermute mal, dass der Metallrahmen auch mit Klebstoff von hinten am Display befestigt ist. Wenn du sagst, dass du ihn nicht mehr fest bekommst, liegt es daran dass es nicht mehr klebt oder der Klebstoff verformt ist. Falls noch gut in FOrm kann es schon genügen ihn warm zu machen und wieder ran zu drücken. Ansonsten muss man womöglich den alten Klebstoff entfernen, die Stelle reinigen und neuen Klebstoff anbringen. Zum Reinigen benutzt du am besten Isopropanol (>90%). Als Klebstoff bietet sich dieses doppelseitiges Klebeband an (könnte evtl aber auch zu schwach sein zwecks des Drucks auf den Button) oder ein Klebstoff wie der E6000. Allerdings ist es schwer zu sagen wie die Stoffe sich mit dem Display vertragen. Auf jeden Fall viel Erfolg mit der Reparatur.
Tobias Isakeit - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 28
Ultimos 30 días: 120
Todo El Tiempo: 35,352
