Saltar al contenido principal
Huawei P10 Plus Display Replacement
Qué necesitas
  1. Huawei P10 Plus Display Replacement, Display: paso 1, imagen 1 de 3 Huawei P10 Plus Display Replacement, Display: paso 1, imagen 2 de 3 Huawei P10 Plus Display Replacement, Display: paso 1, imagen 3 de 3
    • Use an iOpener to loosen the adhesive beneath the display, focusing on the upper and lower part of the display.
    • Use an opening pick, or iFlex, to separate the adhesive on all sides of the display.
    • To avoid damage to the display, do not push the tool too deeply into the phone.
  2. Huawei P10 Plus Display Replacement: paso 2, imagen 1 de 3 Huawei P10 Plus Display Replacement: paso 2, imagen 2 de 3 Huawei P10 Plus Display Replacement: paso 2, imagen 3 de 3
    • There is a thin display cable between the screen and phone, be very careful not to rip it when opening the device.
    • Place a suction cup, or iSclack, on the upper portion of the phone and lift the display off the midframe.
    • Don't remove the display, the cable is trapped under a bracket screwed to the phone. You can flip the display to lay it down without straining the cable, or simply hold it in the next steps.
  3. Huawei P10 Plus Display Replacement, Unfasten the screw: paso 3, imagen 1 de 1
    • Remove the 3.3 mm-long Phillips screw securing the display flex connector bracket.
  4. Huawei P10 Plus Display Replacement: paso 4, imagen 1 de 3 Huawei P10 Plus Display Replacement: paso 4, imagen 2 de 3 Huawei P10 Plus Display Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Tesa 61395 Tape
    $5.99
    Comprar
    • Open the metal bracket that covers the display flex cable.
    • Use a spudger to disconnect the display flex cable.
    • Remove the display.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
Conclusión
8 personas más completaron esta guía.
Tobias Isakeit
Miembro Desde 03/31/14
119,222 Reputación
189 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 56
Todo El Tiempo: 13,767
