Introducción
Use this guide to replace the screen adhesive on your Nintendo Switch Lite.
Follow this guide to remove the screen if you haven't already.
Qué necesitas
Apply high concentration (90% or greater) isopropyl alcohol to the old screen adhesive on the frame.
Wait one minute to allow the alcohol to penetrate the adhesive.
Herramienta utilizada en este paso:Microfiber Cleaning Cloths$3.99
Use the flat end of a spudger to scrape all the old adhesive from the frame.
Use a microfiber cloth to clean the frame.
Apply the adhesive strips sticky side down to the back of the screen, making sure the tape goes under the screen and digitizer cables.
Orient the screen before adhering it to the frame:
The right edge of the screen has two wide cables that line up with the action buttons.
The left edge of the screen has one small cable that lines up with the directional pad.
Lay the right edge of the screen on the frame at a downward angle, making sure its cables go under the frame.
Press down firmly around the perimeter of the screen to adhere it to the frame.
7 personas más completaron esta guía.
