Saltar al contenido principal
How to Open Your Logitech MX Anywhere 3 for Mac
Qué necesitas
  1. How to Open Your Logitech MX Anywhere 3 for Mac, Soften the mouse feet adhesive: paso 1, imagen 1 de 2 How to Open Your Logitech MX Anywhere 3 for Mac, Soften the mouse feet adhesive: paso 1, imagen 2 de 2
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the mouse feet for about two minutes.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
  2. How to Open Your Logitech MX Anywhere 3 for Mac, Disassembly information: paso 2, imagen 1 de 2 How to Open Your Logitech MX Anywhere 3 for Mac, Disassembly information: paso 2, imagen 2 de 2
    • There are small gaps in the rims surrounding each foot. This is where to place the tool in the next step.
  3. How to Open Your Logitech MX Anywhere 3 for Mac, Remove the feet: paso 3, imagen 1 de 3 How to Open Your Logitech MX Anywhere 3 for Mac, Remove the feet: paso 3, imagen 2 de 3 How to Open Your Logitech MX Anywhere 3 for Mac, Remove the feet: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Push the tip of an opening pick underneath the mouse foot adhesive, into the gap in the rim.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Repeat to remove the three remaining mouse feet.
    • For installing new mouse feet or reusing your old ones:
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive. Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
  4. How to Open Your Logitech MX Anywhere 3 for Mac, Remove the case screws: paso 4, imagen 1 de 1
    • Use a Phillips screwdriver to remove the four 4.3 mm-long screws securing the two halves of the mouse together.
  5. How to Open Your Logitech MX Anywhere 3 for Mac, Open the mouse: paso 5, imagen 1 de 3 How to Open Your Logitech MX Anywhere 3 for Mac, Open the mouse: paso 5, imagen 2 de 3 How to Open Your Logitech MX Anywhere 3 for Mac, Open the mouse: paso 5, imagen 3 de 3
    • Gently open the top half of the mouse up and flip it over to the right, like a book.
    • Don't try to fully remove the top shell just yet—a cable connects the upper shell to the lower case.
  6. How to Open Your Logitech MX Anywhere 3 for Mac, Disconnect the interconnect cable: paso 6, imagen 1 de 2 How to Open Your Logitech MX Anywhere 3 for Mac, Disconnect the interconnect cable: paso 6, imagen 2 de 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
  7. How to Open Your Logitech MX Anywhere 3 for Mac: paso 7, imagen 1 de 2 How to Open Your Logitech MX Anywhere 3 for Mac: paso 7, imagen 2 de 2
    • Pull the cable straight out of its socket.
    • During reassembly, insert the cable with its blue tab facing up, then flip down the locking flap.
  8. How to Open Your Logitech MX Anywhere 3 for Mac, Remove the top half of the mouse: paso 8, imagen 1 de 1
    • Remove the top half of the mouse.
Conclusión
Una persona más ha completado esta guía.
Clay Eickemeyer
Miembro Desde 09/19/22
67,399 Reputación
453 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,430 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 26
Todo El Tiempo: 317
