Saltar al contenido principal
How to Install an M.2 SSD
Qué necesitas
  1. How to Install an M.2 SSD, Reposition the standoff: paso 1, imagen 1 de 2 How to Install an M.2 SSD, Reposition the standoff: paso 1, imagen 2 de 2
    • If your laptop did not include a removable standoff or only supports one M.2 SSD form factor, you can skip this step.
    • Use a screwdriver to remove the preinstalled standoff.
    • If your laptop does not include a preinstalled standoff, you will need to get one.
    • Find the correct standoff location that corresponds to your desired M.2 SSD form factor.
    • Screw in the standoff.
  2. How to Install an M.2 SSD, Insert the SSD: paso 2, imagen 1 de 3 How to Install an M.2 SSD, Insert the SSD: paso 2, imagen 2 de 3 How to Install an M.2 SSD, Insert the SSD: paso 2, imagen 3 de 3
    • Grip the SSD on the sides near the screw indent.
    • Gently slide the SSD into the socket at about a 30˚ angle.
    • The socket is spring loaded and will support the SSD at an angle.
  3. How to Install an M.2 SSD, Screw down the SSD: paso 3, imagen 1 de 3 How to Install an M.2 SSD, Screw down the SSD: paso 3, imagen 2 de 3 How to Install an M.2 SSD, Screw down the SSD: paso 3, imagen 3 de 3
    • Use your finger to hold the SSD down horizontally, making sure that the screw indent aligns with the standoff.
    • Screw down the SSD to secure it.
  4. How to Install an M.2 SSD, Apply a thermal pad: paso 4, imagen 1 de 3 How to Install an M.2 SSD, Apply a thermal pad: paso 4, imagen 2 de 3 How to Install an M.2 SSD, Apply a thermal pad: paso 4, imagen 3 de 3
    • If your laptop did not have a thermal pad installed, you can skip this step.
    • Use tweezers or your fingers to place a thermal pad on the top of the SSD.
    • The original thermal pad can be reused if it is clean and undamaged.
Conclusión
Installation didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
4 personas más completaron esta guía.
Chayton Ritter
Miembro Desde 08/21/20
6,233 Reputación
36 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
139 Miembros
16,881 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 42
Ultimos 30 días: 200
Todo El Tiempo: 948
