Saltar al contenido principal
How to Install a New Battery in Your Samsung Galaxy S22 Ultra
Qué necesitas
  1. How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Clean the frame: paso 1, imagen 1 de 2 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Clean the frame: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use your fingers or tweezers to peel up and remove any large pieces of adhesive from the frame.
    • Apply a few drops of highly-concentrated isopropyl alcohol (greater than 90%) to the remaining adhesive.
    • Use the flat end of a spudger to scrape off all remaining adhesive.
  2. How to Install a New Battery in Your Samsung Galaxy S22 Ultra: paso 2, imagen 1 de 1
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • Apply a few more drops of highly-concentrated isopropyl alcohol (greater than 90%) to any adhesive residue on the frame and wipe it away with a microfiber or lint-free cloth.
  3. How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Measure and cut the tape: paso 3, imagen 1 de 3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Measure and cut the tape: paso 3, imagen 2 de 3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Measure and cut the tape: paso 3, imagen 3 de 3
    Tesa 61395 Tape
    $2.99
    Comprar
  4. How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Apply the strips of tape: paso 4, imagen 1 de 3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Apply the strips of tape: paso 4, imagen 2 de 3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Apply the strips of tape: paso 4, imagen 3 de 3
    • Lay a strip of tape onto the frame.
    • Use the flat end of your spudger to press down firmly along the whole strip to secure it.
    • Use tweezers to remove the liner from the strip of tape.
  5. How to Install a New Battery in Your Samsung Galaxy S22 Ultra: paso 5, imagen 1 de 3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra: paso 5, imagen 2 de 3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra: paso 5, imagen 3 de 3
    • Repeat the previous step to apply the remaining strips of tape.
  6. How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Secure the battery: paso 6, imagen 1 de 3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Secure the battery: paso 6, imagen 2 de 3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Secure the battery: paso 6, imagen 3 de 3
    • While holding the battery above its recess, reconnect the battery cable.
    • This ensures the battery is properly aligned.
    • Lay the battery into its recess in the frame.
    • Press down firmly on the entire surface of the battery to secure it with the tape.
    • Disconnect the battery.
    • Return to your repair guide and continue reassembly.
Conclusión
For optimal performance, calibrate your newly installed battery after completing your repair.
Spencer Day
Miembro Desde 09/14/22
55,176 Reputación
408 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,420 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 33
Ultimos 30 días: 157
Todo El Tiempo: 1,243
