Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Install Ubuntu Linux
Qué necesitas
    1. How to Install Ubuntu Linux, Download Ubuntu: paso 1, imagen 1 de 1
      Pregunta a FixBot
      Agregar Comentario
    2. How to Install Ubuntu Linux, Burn to Disk: paso 2, imagen 1 de 2 How to Install Ubuntu Linux, Burn to Disk: paso 2, imagen 2 de 2
      • Use disk burning software like ImgBurn to burn Ubuntu to a DVD, or you can use a USB flash drive instead. If you use a flash drive, download UNetbootin and create your installation media.
      • You do not need to burn Ubuntu to a disk if you are using a virtual machine.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Install Ubuntu Linux, Boot to installation media: paso 3, imagen 1 de 1
      • I recommend trying Ubuntu in a virtual machine, which is what I did.
      • If you are using a real computer, you may need to configure the BIOS or press a key on system startup. If you need to change the BIOS settings, set any Optical Drives or USB CD-ROM drives as the first boot priority.
      • If you want to use a virtual machine, set CD/DVD as the first boot priority and mount the iso file to the machine. There is plenty of virtualization software out there, like VirtualBox.
      • If you have successfully booted into the installation media, you will see this picture.
      • Click on the big "Install Ubuntu" button.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Install Ubuntu Linux, Install Ubuntu: paso 4, imagen 1 de 1
      • After a screen asking about additional software, you will asked what you would like to do with your hard disk.
      • If the installer refers to any sort of dual-booting, you must quit the installer and make unallocated space on your hard disk somehow. (See warning for info.)
      • If you are experienced with partitions, you may use this partition editor.
      • If you decide to use the partition editor, please be very careful. Partitions made with this partition editor can cause any other operating systems to become inaccessible.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
That's it! Now you can try Ubuntu all you want.
7 personas más completaron esta guía.
Thomas Sirack
Miembro Desde 07/25/15
561 Reputación
2 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 27
Todo El Tiempo: 1,577
