Introducción
iOS 13 update has again brought the True Tone missing problem to some iPhone users. Well, some people have worked out a new solution to fix the problem. We will take iPhone XS as an example and show you how to restore True Tone of aftermarket screens step by step.
Qué necesitas
Resumen del Video
Go to Settings>General>About and check the software version of the phone – iOS 13.2. Tap Display & Brightness. We can see that the True Tone has been turned on with the switch being green.
Replace with a new aftermarket screen.
Tap Display & Brightness. We can see that the true tone option has vanished.
Now, let’s restore the true tone with the multi-functional programmer.
First, connect the display extended module with the programmer. Next, connect the original screen with the display extended module.
Then we need to use the programmer to read data on the original screen.
Once finished, disconnect the original screen and connect the aftermarket screen with the display extended module.
This time we use the programmer to write the data to the aftermarket screen. Once finished, disconnect the aftermarket screen.
Go to Settings>General>About and check the software version of the phone – iOS 13.2. Continue to tap Display & Brightness. We can see that there is no true tone option.
Connect the phone to the computer and open the WL assistance software. The cover board number of the phone has been read automatically.
Continue to power off and disconnect the phone from the computer. Remove the aftermarket screen afterwards.
Now, let’s restore the true tone without the original screen.
Connect the aftermarket screen with the display extended module and connect the multi-functional true tone programmer to the computer.
To restore true tone without the original screen, we need to write the previously read cover board number to the aftermarket screen with the help of the software.
Now we can assemble the phone and test. Get the aftermarket screen installed and connect the battery. Press the power button to turn on the phone.
Continue to tap Display & Brightness. We can see that the True Tone has been turned on with the switch being green. The True Tone has been restored back.
26 personas más completaron esta guía.
26 comentarios
Would this work with an original screen on another body?
Really nice fix!
I had installed an original iPhone screen from another body on my iPhoneXS . I used this tool for restoring TrueTone and it worked like a charm!
Hi is there any msg “ iphone canot check your screen”
