Saltar al contenido principal
Hasbro Bop-It Micro Series Speaker Replacement
Qué necesitas
  1. Hasbro Bop-It Micro Series Speaker Replacement, Back Case: paso 1, imagen 1 de 1
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Speaker Replacement: paso 3, imagen 1 de 1
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Speaker Replacement, Speaker: paso 4, imagen 1 de 2 Hasbro Bop-It Micro Series Speaker Replacement, Speaker: paso 4, imagen 2 de 2
    • Remove the (3) #3 Phillips head 6 mm screws using your Phillips #0 screwdriver, and remove the plastic with your fingers.
  5. Hasbro Bop-It Micro Series Speaker Replacement: paso 5, imagen 1 de 1
    • De-solder the speaker from the wires. Refer to the soldering guide for instructions on how to solder
Conclusión
Follow the steps of this guide in reverse to reassemble.
2 personas más completaron esta guía.
Glenn Haag
Miembro Desde 09/29/16
479 Reputación
3 Guías creadas
Equipo
IUPUI, Team 3-1, Harley Fall 2016 Miembro de IUPUI, Team 3-1, Harley Fall 2016
IUPUI-HARLEY-F16S3G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 1,408
