Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Stream 7 Screen Replacement
Qué necesitas
    1. HP Stream 7  Screen Replacement, Battery: paso 1, imagen 1 de 2 HP Stream 7  Screen Replacement, Battery: paso 1, imagen 2 de 2
      • Make sure the tablet is powered off before beginning.
      • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
      Pregunta a FixBot
      Agregar Comentario
    2. HP Stream 7  Screen Replacement: paso 2, imagen 1 de 2 HP Stream 7  Screen Replacement: paso 2, imagen 2 de 2
      • Remove the eight 5 mm Phillips 000 screws.
      • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
      Pregunta a FixBot
      Agregar Comentario
    3. HP Stream 7  Screen Replacement: paso 3, imagen 1 de 2 HP Stream 7  Screen Replacement: paso 3, imagen 2 de 2
      Herramienta utilizada en este paso:
      • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
      • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
      • If you broke both tabs, scrape the tape and Battery off.
      • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
      Pregunta a FixBot
      Agregar Comentario
    1. HP Stream 7  Screen Replacement, Motherboard Replacement: paso 4, imagen 1 de 1
      • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
      • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
      • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
      • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
      Pregunta a FixBot
      Agregar Comentario
    2. HP Stream 7  Screen Replacement: paso 5, imagen 1 de 2 HP Stream 7  Screen Replacement: paso 5, imagen 2 de 2
      • Remove the two 2 mm Phillips 000 screws from the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    3. HP Stream 7  Screen Replacement: paso 6, imagen 1 de 2 HP Stream 7  Screen Replacement: paso 6, imagen 2 de 2
      • Once unscrewed, the motherboard separates from the rest of the device.
      • The speaker is soldered to the motherboard, but it comes off easily.
      • Forced separation may result in a damaged motherboard and/or personal injury.
      Pregunta a FixBot
      Agregar Comentario
    1. HP Stream 7  Screen Replacement, Screen Replacement: paso 7, imagen 1 de 1
      • After removing the motherboard, unscrew the four 2.5 mm Phillips 000 screws from the display panel.
      Pregunta a FixBot
      Agregar Comentario
    2. HP Stream 7  Screen Replacement: paso 8, imagen 1 de 1
      • Using your spudger, pry the display panel off the front.
      Pregunta a FixBot
      Agregar Comentario
    3. HP Stream 7  Screen Replacement: paso 9, imagen 1 de 1
      • The screen should now just come right off. Be sure to catch any broken bits if the screen is damaged.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
6 personas más completaron esta guía.
Equipo
Cal Poly, Team 18-5, Forte Fall 2016 Miembro de Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
Miembros de 4
6 Guías creadas
6Guía Comentarios
where can i buy new screen????
eibrims - Contestar Compartir
Yeah, I want to know where I can buy a screen for my hp stream 7.
Rider Sd - Contestar Compartir
Where can i buy a new screen for the stream 7 please??
migueajr - Contestar Compartir
Same question but no answer !
Where can anyone find replacement screen online ??
Ahmed Saleh - Contestar Compartir
We're I can buy the replacement screen?
Raymond Borrero - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 4,724
