Introducción
This guide shows how to remove and replace the M.2 blade SSD for the HP Spectre x360 15t-ap000 laptop.
The laptop has a standard M.2 slot, so any M.2 form factor SSD will work with the laptop.
Qué necesitas
Use a T5 driver to remove the following screws securing the back cover:
Six 4 mm-long screws
Two 7.8 mm-long screws
Use an opening tool or your fingers to pry up the back cover from the laptop.
Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
Gently pull the connector parallel to the motherboard to disconnect it.
Use your fingers or tweezers to peel the black plastic strip until you uncover the SSD.
Una persona más ha completado esta guía.
