Saltar al contenido principal
HP EliteBook x360 830 G6 Back Cover Replacement
Qué necesitas
  1. HP EliteBook x360 830 G6 Back Cover Replacement, Unfasten the back cover: paso 1, imagen 1 de 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Back Cover Replacement, Release the clips: paso 2, imagen 1 de 2 HP EliteBook x360 830 G6 Back Cover Replacement, Release the clips: paso 2, imagen 2 de 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Back Cover Replacement, Release the remaining clips: paso 3, imagen 1 de 2 HP EliteBook x360 830 G6 Back Cover Replacement, Release the remaining clips: paso 3, imagen 2 de 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Back Cover Replacement, Remove the back cover: paso 4, imagen 1 de 3 HP EliteBook x360 830 G6 Back Cover Replacement, Remove the back cover: paso 4, imagen 2 de 3 HP EliteBook x360 830 G6 Back Cover Replacement, Remove the back cover: paso 4, imagen 3 de 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Clay Eickemeyer
Miembro Desde 09/19/22
69,499 Reputación
453 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
141 Miembros
17,895 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 68
Todo El Tiempo: 808
