Saltar al contenido principal
HP EliteBook 835 G7 Lower Case Replacement
Qué necesitas
  1. HP EliteBook 835 G7 Lower Case Replacement, Remove the Phillips screws: paso 1, imagen 1 de 2 HP EliteBook 835 G7 Lower Case Replacement, Remove the Phillips screws: paso 1, imagen 2 de 2
    • Completely power off and unplug your EliteBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a Phillips screwdriver to loosen the five captive screws from the lower case.
  2. HP EliteBook 835 G7 Lower Case Replacement, Release the case's right clips: paso 2, imagen 1 de 3 HP EliteBook 835 G7 Lower Case Replacement, Release the case's right clips: paso 2, imagen 2 de 3 HP EliteBook 835 G7 Lower Case Replacement, Release the case's right clips: paso 2, imagen 3 de 3
    • Insert an opening pick between the lower case and the chassis along the hinge edge.
    • Slide the opening pick around the right corner and halfway up the side of the EliteBook to release the clips securing the lower case.
  3. HP EliteBook 835 G7 Lower Case Replacement, Release the case's left clips: paso 3, imagen 1 de 3 HP EliteBook 835 G7 Lower Case Replacement, Release the case's left clips: paso 3, imagen 2 de 3 HP EliteBook 835 G7 Lower Case Replacement, Release the case's left clips: paso 3, imagen 3 de 3
    • Repeat the previous step on the left side of the case to release the clips.
  4. HP EliteBook 835 G7 Lower Case Replacement, Remove the lower case: paso 4, imagen 1 de 3 HP EliteBook 835 G7 Lower Case Replacement, Remove the lower case: paso 4, imagen 2 de 3 HP EliteBook 835 G7 Lower Case Replacement, Remove the lower case: paso 4, imagen 3 de 3
    • Lift the lower case up and away from the EliteBook and remove it.
Conclusión
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our HP Elitebook answers community for help.
Spencer Day
Miembro Desde 09/14/22
95,649 Reputación
662 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,537 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 12
Ultimos 30 días: 37
Todo El Tiempo: 497
