Introducción
Use this guide to replace one or both of the rubber feet on your HP 15s Laptop PC.
Note: This procedure was written using a model 15-dw3033dx HP 15s Laptop PC, but is fully compatible with any HP 15s Laptop PC whose model number starts with 15-dw.
Qué necesitas
Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
Peel the rear foot away from the back cover and remove it.
The front foot is thicker, with a deeper recess.
The rear foot is thinner, with a shallower recess.
If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
