Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP 15-R263DX USB Port Replacement
Qué necesitas
  1. HP 15-R263DX USB Port Replacement, Battery: paso 1, imagen 1 de 2 HP 15-R263DX USB Port Replacement, Battery: paso 1, imagen 2 de 2
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
    Pregunta a FixBot
    Agregar Comentario
  2. HP 15-R263DX USB Port Replacement, Optical Drive: paso 2, imagen 1 de 2 HP 15-R263DX USB Port Replacement, Optical Drive: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
    Pregunta a FixBot
    Agregar Comentario
  3. HP 15-R263DX USB Port Replacement: paso 3, imagen 1 de 1
    • Gently slide the optical drive out of the side of the computer.
    Pregunta a FixBot
    Agregar Comentario
  4. HP 15-R263DX USB Port Replacement, HP 15-R263DX Disassembly: paso 4, imagen 1 de 2 HP 15-R263DX USB Port Replacement, HP 15-R263DX Disassembly: paso 4, imagen 2 de 2
    • Locate the two corner grips on the hinge side of the computer.
    • Using a metal spudger, remove the two corner grips to reveal the screws.
    Pregunta a FixBot
    Agregar Comentario
  5. HP 15-R263DX USB Port Replacement: paso 5, imagen 1 de 1
    • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
    Pregunta a FixBot
    Agregar Comentario
  6. HP 15-R263DX USB Port Replacement: paso 6, imagen 1 de 1
    • Remove the 2 small screws that are on the bottom side of the disc tray slot.
    • These screws are shorter and wider than the others.
    Pregunta a FixBot
    Agregar Comentario
  7. HP 15-R263DX USB Port Replacement: paso 7, imagen 1 de 2 HP 15-R263DX USB Port Replacement: paso 7, imagen 2 de 2
    • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
    • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
    Pregunta a FixBot
    Agregar Comentario
  8. HP 15-R263DX USB Port Replacement: paso 8, imagen 1 de 2 HP 15-R263DX USB Port Replacement: paso 8, imagen 2 de 2
    • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
    • Remove the 4 small screws shown in the picture.
    Pregunta a FixBot
    Agregar Comentario
  9. HP 15-R263DX USB Port Replacement: paso 9, imagen 1 de 1
    • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
    • The face plate can then be lifted away from the computer.
    Pregunta a FixBot
    Agregar Comentario
  10. HP 15-R263DX USB Port Replacement, Hard Drive: paso 10, imagen 1 de 1
    • Remove the 2 black screws holding the hard drive to the computer frame.
    Pregunta a FixBot
    Agregar Comentario
  11. HP 15-R263DX USB Port Replacement: paso 11, imagen 1 de 2 HP 15-R263DX USB Port Replacement: paso 11, imagen 2 de 2
    • Gently slide the hard drive away from the motherboard to disconnect it.
    • After it's disconnected, lift the hard drive up to remove it from the computer.
    Pregunta a FixBot
    Agregar Comentario
  12. HP 15-R263DX USB Port Replacement, USB Port: paso 12, imagen 1 de 1
    • Remove the single screw holding the USB ports and chip into the computer.
    Pregunta a FixBot
    Agregar Comentario
  13. HP 15-R263DX USB Port Replacement: paso 13, imagen 1 de 1
    • Remove the chip by gently pulling it up and then away from the edge of the case.
    Pregunta a FixBot
    Agregar Comentario
  14. HP 15-R263DX USB Port Replacement: paso 14, imagen 1 de 1
    • Under the motherboard, disconnect the wire that runs to the USB chip.
    • You may need to pull or wedge the wire up from the case as a section of it is glued down.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Drake Hort
Miembro Desde 03/05/18
487 Reputación
3 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 37
Todo El Tiempo: 799
