Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP 15-R263DX Keyboard Replacement
Qué necesitas
  1. HP 15-R263DX Keyboard Replacement, Battery: paso 1, imagen 1 de 2 HP 15-R263DX Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
    Pregunta a FixBot
    Agregar Comentario
  2. HP 15-R263DX Keyboard Replacement, Keyboard: paso 2, imagen 1 de 1
    • Once keyboard is loose, do not immediately remove it from the computer. It is attached by a ribbon connector.
    • Using a metal wedge tool, pry up along the top edge of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    Pregunta a FixBot
    Agregar Comentario
  3. HP 15-R263DX Keyboard Replacement: paso 3, imagen 1 de 1
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 677
