Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP 15-R011DX RAM (Random Access Memory) Replacement
Qué necesitas
  1. HP 15-R011DX RAM (Random Access Memory) Replacement, Battery: paso 1, imagen 1 de 2 HP 15-R011DX RAM (Random Access Memory) Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the lock mechanism on the left side of the laptop to the right.
    Pregunta a FixBot
    Agregar Comentario
  2. HP 15-R011DX RAM (Random Access Memory) Replacement: paso 2, imagen 1 de 1
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
    Pregunta a FixBot
    Agregar Comentario
  3. HP 15-R011DX RAM (Random Access Memory) Replacement, How to Access the Internal Components of an HP 15-R011DX: paso 3, imagen 1 de 2 HP 15-R011DX RAM (Random Access Memory) Replacement, How to Access the Internal Components of an HP 15-R011DX: paso 3, imagen 2 de 2
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
    Pregunta a FixBot
    Agregar Comentario
  4. HP 15-R011DX RAM (Random Access Memory) Replacement: paso 4, imagen 1 de 2 HP 15-R011DX RAM (Random Access Memory) Replacement: paso 4, imagen 2 de 2
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
    Pregunta a FixBot
    Agregar Comentario
  5. HP 15-R011DX RAM (Random Access Memory) Replacement: paso 5, imagen 1 de 2 HP 15-R011DX RAM (Random Access Memory) Replacement: paso 5, imagen 2 de 2
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
    Pregunta a FixBot
    Agregar Comentario
  6. HP 15-R011DX RAM (Random Access Memory) Replacement: paso 6, imagen 1 de 3 HP 15-R011DX RAM (Random Access Memory) Replacement: paso 6, imagen 2 de 3 HP 15-R011DX RAM (Random Access Memory) Replacement: paso 6, imagen 3 de 3
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
    Pregunta a FixBot
    Agregar Comentario
  7. HP 15-R011DX RAM (Random Access Memory) Replacement: paso 7, imagen 1 de 2 HP 15-R011DX RAM (Random Access Memory) Replacement: paso 7, imagen 2 de 2
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
    Pregunta a FixBot
    Agregar Comentario
  8. HP 15-R011DX RAM (Random Access Memory) Replacement, Hard Drive: paso 8, imagen 1 de 1
    • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
    Pregunta a FixBot
    Agregar Comentario
  9. HP 15-R011DX RAM (Random Access Memory) Replacement: paso 9, imagen 1 de 2 HP 15-R011DX RAM (Random Access Memory) Replacement: paso 9, imagen 2 de 2
    • Pull the hard drive upwards and away from the laptop.
    • The hard drive should disconnect from its port on the motherboard as shown in the second image.
    Pregunta a FixBot
    Agregar Comentario
  10. HP 15-R011DX RAM (Random Access Memory) Replacement: paso 10, imagen 1 de 1
    • Flip the hard drive over.
    • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
    • Remove the mounting brace (silver bracket) from the hard drive.
    Pregunta a FixBot
    Agregar Comentario
  11. HP 15-R011DX RAM (Random Access Memory) Replacement, Motherboard: paso 11, imagen 1 de 2 HP 15-R011DX RAM (Random Access Memory) Replacement, Motherboard: paso 11, imagen 2 de 2
    • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  12. HP 15-R011DX RAM (Random Access Memory) Replacement: paso 12, imagen 1 de 1
    • Remove the tape from the display connector attached to the motherboard.
    • Disconnect the display connector from the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  13. HP 15-R011DX RAM (Random Access Memory) Replacement: paso 13, imagen 1 de 1
    • Remove one 4 mm Phillips #1 screw from the wireless chip.
    • Remove the wireless chip from the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  14. HP 15-R011DX RAM (Random Access Memory) Replacement: paso 14, imagen 1 de 1
    • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
    • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
    Pregunta a FixBot
    Agregar Comentario
  15. HP 15-R011DX RAM (Random Access Memory) Replacement: paso 15, imagen 1 de 1
    • Slowly lift the motherboard out of the computer.
    • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
    • Disconnect the power connector from the motherboard as shown in the image.
    Pregunta a FixBot
    Agregar Comentario
  16. HP 15-R011DX RAM (Random Access Memory) Replacement, RAM (Random Access Memory): paso 16, imagen 1 de 1
    • Locate the RAM drive on the underside of the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  17. HP 15-R011DX RAM (Random Access Memory) Replacement: paso 17, imagen 1 de 2 HP 15-R011DX RAM (Random Access Memory) Replacement: paso 17, imagen 2 de 2
    • Push the locking tabs outward to release the RAM chip from the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  18. HP 15-R011DX RAM (Random Access Memory) Replacement: paso 18, imagen 1 de 1
    • Remove the RAM chip by pulling the drive from the connectors.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 23
Todo El Tiempo: 1,416
