Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Google Pixel C Keyboard Replacement
Qué necesitas
    1. Google Pixel C Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
      • Heat the black plastic strip on the front lower edge of the keyboard with an iOpener to weaken the adhesive holding it down.
      • When reattaching the plastic strip, apply adhesive to ensure that the strip will stay securely in place.
      Pregunta a FixBot
      Agregar Comentario
    2. Google Pixel C Keyboard Replacement: paso 2, imagen 1 de 2 Google Pixel C Keyboard Replacement: paso 2, imagen 2 de 2
      • Use a medium plastic opening tool to lift the black plastic strip from the lower edge of the keyboard.
      Pregunta a FixBot
      Agregar Comentario
    3. Google Pixel C Keyboard Replacement: paso 3, imagen 1 de 2 Google Pixel C Keyboard Replacement: paso 3, imagen 2 de 2
      • Locate the four 3.1mm Phillips #000 screws that hold the keyboard to the back plate.
      • Using the Phillips #000 Screwdriver, remove the screws from the keyboard.
      • The screws are reverse threaded, so turn them clockwise to remove them.
      Pregunta a FixBot
      Agregar Comentario
    4. Google Pixel C Keyboard Replacement: paso 4, imagen 1 de 1
      • Orient the keyboard so that the side with the keys is facedown on the table.
      • Use either an iFixit iOpener OR a heat gun to melt the adhesive that holds the top half of the keyboard to the bottom.
      • When using a heat gun for removal, only heat the backside of the keyboard to avoid warping the keys.
      Pregunta a FixBot
      Agregar Comentario
    5. Google Pixel C Keyboard Replacement: paso 5, imagen 1 de 3 Google Pixel C Keyboard Replacement: paso 5, imagen 2 de 3 Google Pixel C Keyboard Replacement: paso 5, imagen 3 de 3
      • Using a plastic or nylon spudger, pry the two halves of the keyboard apart.
      • If the plastic spudger doesn’t work, it is okay to use a metal spudger, but take care not to scratch or damage the device.
      • Be mindful of the amount of force applied to avoid snapping the keyboard.
      • It will be necessary to use adhesive to ensure that the keyboard is securely in place during reassembly.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team S21-G4, Livingston Spring 2017 Miembro de Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
Miembros de 4
21 Guías creadas
1Guía Comentario
Uninstall a Pixel c's keyboard case's battery system,The Battery is out of life, but the case cost Pixel c's power while closed. No suitable battery to replace temporarily. Use a Hot Gun with higher temparature but control the temparature not too high then you will easily peal off the skin but no any broken and finally you can adhere it back to normal.Finished and accept. Now I just use the case as a case only and no need consider it cost the power.
bgzhang - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 34
Todo El Tiempo: 2,494
