Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
GeeksPhone Keon Camera Replacement
Qué necesitas
  1. GeeksPhone Keon  Camera Replacement, Battery: paso 1, imagen 1 de 2 GeeksPhone Keon  Camera Replacement, Battery: paso 1, imagen 2 de 2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
    Pregunta a FixBot
    Agregar Comentario
  2. GeeksPhone Keon  Camera Replacement: paso 2, imagen 1 de 1
    • Lift the cover away from the phone.
    Pregunta a FixBot
    Agregar Comentario
  3. GeeksPhone Keon  Camera Replacement: paso 3, imagen 1 de 1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
    Pregunta a FixBot
    Agregar Comentario
  4. GeeksPhone Keon  Camera Replacement, Back Plate: paso 4, imagen 1 de 2 GeeksPhone Keon  Camera Replacement, Back Plate: paso 4, imagen 2 de 2
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
    Pregunta a FixBot
    Agregar Comentario
  5. GeeksPhone Keon  Camera Replacement: paso 5, imagen 1 de 2 GeeksPhone Keon  Camera Replacement: paso 5, imagen 2 de 2
    • Gently remove the small orange plate by pulling it down.
    Pregunta a FixBot
    Agregar Comentario
  6. GeeksPhone Keon  Camera Replacement: paso 6, imagen 1 de 1
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
    Pregunta a FixBot
    Agregar Comentario
  7. GeeksPhone Keon  Camera Replacement: paso 7, imagen 1 de 3 GeeksPhone Keon  Camera Replacement: paso 7, imagen 2 de 3 GeeksPhone Keon  Camera Replacement: paso 7, imagen 3 de 3
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
    Pregunta a FixBot
    Agregar Comentario
  8. GeeksPhone Keon  Camera Replacement: paso 8, imagen 1 de 2 GeeksPhone Keon  Camera Replacement: paso 8, imagen 2 de 2
    • Lift the backplate away from the device.
    Pregunta a FixBot
    Agregar Comentario
  9. GeeksPhone Keon  Camera Replacement, Camera: paso 9, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Lift the retaining flap on camera's ZIF connector.
    • Pull the ribbon cable away with tweezers.
    Pregunta a FixBot
    Agregar Comentario
  10. GeeksPhone Keon  Camera Replacement: paso 10, imagen 1 de 3 GeeksPhone Keon  Camera Replacement: paso 10, imagen 2 de 3 GeeksPhone Keon  Camera Replacement: paso 10, imagen 3 de 3
    • Carefully wiggle the camera away from the device.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
To reassemble your device, follow these instructions in reverse order; but remember, the new camera must be glued back in place where the old one was removed.
Bryan Bittner
Miembro Desde 08/26/15
167 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 3-5, Eyestone Fall 2015 Miembro de USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
Miembros de 4
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 25
Todo El Tiempo: 354
