Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Gateway SA1 RAM Replacement
Qué necesitas
  1. Gateway SA1 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Move the latch to the right of the battery to unlock.
    Pregunta a FixBot
    Agregar Comentario
  2. Gateway SA1 RAM Replacement: paso 2, imagen 1 de 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
    Pregunta a FixBot
    Agregar Comentario
  3. Gateway SA1 RAM Replacement, RAM: paso 3, imagen 1 de 2 Gateway SA1 RAM Replacement, RAM: paso 3, imagen 2 de 2
    • Loosen the indicated Philips screw that connects the memory bay cover to the casing.
    • The indicated Philips screw does not come out of the cover.
    Pregunta a FixBot
    Agregar Comentario
  4. Gateway SA1 RAM Replacement: paso 4, imagen 1 de 2 Gateway SA1 RAM Replacement: paso 4, imagen 2 de 2
    • Lift and remove the cover using the spudger.
    Pregunta a FixBot
    Agregar Comentario
  5. Gateway SA1 RAM Replacement: paso 5, imagen 1 de 2 Gateway SA1 RAM Replacement: paso 5, imagen 2 de 2
    • Gently press the clip outwards.
    • The module will tilt up and can be pulled out of the slot.
    • There may be another memory module underneath so be sure to remove both.
    Pregunta a FixBot
    Agregar Comentario
  6. Gateway SA1 RAM Replacement: paso 6, imagen 1 de 1
    • To insert a new memory, slide the module into the slot at a 30 to 45 degree angle.
    • Place the first module into the bottom slot then the next module into the top slot.
    • These slots are keyed so verify that you are sliding the module in one direction.
    • Verify that the new memory modules are designed for your specific Gateway Laptop.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 24-20, Regan Spring 2010 Miembro de Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
Miembros de 4
14 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 34
Todo El Tiempo: 6,069
