Introducción
If your laptop screen is not functioning properly, use this guide to replace the display. This is a difficult repair that requires the laptop to be nearly completely disassembled. This level of disassembly requires handling multiple fragile components, so caution should be used.
Qué necesitas
There are 6 small clips that holding the top row of the keyboard in place.
To remove the keyboard, push each of these clips in with a metal spudger while simultaneously using a plastic opening tool to pry the keyboard up.
Once the top row is loose you can use the plastic opening tool to gently pry the rest of the keyboard off the laptop.
Una persona más ha completado esta guía.
