Saltar al contenido principal
Inglés
Español
Paso 9
There are 6 small clips that holding the top row of the keyboard in place. To remove the keyboard, push each of these clips in with a metal spudger while simultaneously using a plastic opening tool to pry the keyboard up. Once the top row is loose you can use the plastic opening tool to gently pry the rest of the keyboard off the laptop.
  • There are 6 small clips that holding the top row of the keyboard in place.
  • To remove the keyboard, push each of these clips in with a metal spudger while simultaneously using a plastic opening tool to pry the keyboard up.
  • Once the top row is loose you can use the plastic opening tool to gently pry the rest of the keyboard off the laptop.
Insertar traducción aquí
