Inglés
Español
Paso 11
Remove the 3 ribbon cables using a plastic pry tool to gently push the fasteners loose and gently pulling the cables out. Ribbon cables should come out easily once the fasteners are loose. Do not apply too much force. Use a plastic pry tool to disconnect the single pinned connector.
  • Remove the 3 ribbon cables using a plastic pry tool to gently push the fasteners loose and gently pulling the cables out.
  • Ribbon cables should come out easily once the fasteners are loose. Do not apply too much force.
  • Use a plastic pry tool to disconnect the single pinned connector.
Insertar traducción aquí
