Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Gateway MS2285 RAM Replacement
Qué necesitas
  1. Gateway MS2285 RAM Replacement, Turn Laptop Over: paso 1, imagen 1 de 1
    • Turn the laptop over so that the underside is facing towards you.
    Pregunta a FixBot
    Agregar Comentario
  2. Gateway MS2285 RAM Replacement, Unlock The Battery: paso 2, imagen 1 de 2 Gateway MS2285 RAM Replacement, Unlock The Battery: paso 2, imagen 2 de 2
    • Slide the short slider one towards the unlocked lock symbol.
    Pregunta a FixBot
    Agregar Comentario
  3. Gateway MS2285 RAM Replacement, Release The Battery: paso 3, imagen 1 de 2 Gateway MS2285 RAM Replacement, Release The Battery: paso 3, imagen 2 de 2
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
    Pregunta a FixBot
    Agregar Comentario
  4. Gateway MS2285 RAM Replacement, Remove The Battery: paso 4, imagen 1 de 2 Gateway MS2285 RAM Replacement, Remove The Battery: paso 4, imagen 2 de 2
    • Grasp the battery's raised end and lift upwards.
    Pregunta a FixBot
    Agregar Comentario
  5. Gateway MS2285 RAM Replacement, Unscrew Backplate: paso 5, imagen 1 de 2 Gateway MS2285 RAM Replacement, Unscrew Backplate: paso 5, imagen 2 de 2
    • Use the phillips head screwdriver to remove the five screws holding the back plate.
    • The screws are counter-clockwise threaded.
    Pregunta a FixBot
    Agregar Comentario
  6. Gateway MS2285 RAM Replacement, Remove Back Plate: paso 6, imagen 1 de 3 Gateway MS2285 RAM Replacement, Remove Back Plate: paso 6, imagen 2 de 3 Gateway MS2285 RAM Replacement, Remove Back Plate: paso 6, imagen 3 de 3
    • Place fingers under back plate via the indentation and lift upwards to remove.
    Pregunta a FixBot
    Agregar Comentario
  7. Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: paso 7, imagen 1 de 3 Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: paso 7, imagen 2 de 3 Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: paso 7, imagen 3 de 3
    • Push the upper RAM module's two pins outwards at the same time.
    • If done correctly, the module should have lifted.
    Pregunta a FixBot
    Agregar Comentario
  8. Gateway MS2285 RAM Replacement, Remove Upper RAM Module: paso 8, imagen 1 de 2 Gateway MS2285 RAM Replacement, Remove Upper RAM Module: paso 8, imagen 2 de 2
    • Grab onto the module and pull away in a straight direction.
    • Do not touch the gold connectors.
    Pregunta a FixBot
    Agregar Comentario
  9. Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: paso 9, imagen 1 de 3 Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: paso 9, imagen 2 de 3 Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: paso 9, imagen 3 de 3
    • Push the lower RAM module's two pins outwards at the same time.
    Pregunta a FixBot
    Agregar Comentario
  10. Gateway MS2285 RAM Replacement, Remove Lower RAM Module: paso 10, imagen 1 de 3 Gateway MS2285 RAM Replacement, Remove Lower RAM Module: paso 10, imagen 2 de 3 Gateway MS2285 RAM Replacement, Remove Lower RAM Module: paso 10, imagen 3 de 3
    • Like removing the upper module, grab the module and pull away in a straight direction.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Chris mello
Miembro Desde 10/22/14
331 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-7, Shastany Fall 2014 Miembro de UMass Dartmouth, Team 1-7, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G7
Miembros de 3
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 26
Todo El Tiempo: 2,919
