Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Function Key Motherboard
Qué necesitas
    1. Function Key Motherboard, Front and Back Covers: paso 1, imagen 1 de 3 Function Key Motherboard, Front and Back Covers: paso 1, imagen 2 de 3 Function Key Motherboard, Front and Back Covers: paso 1, imagen 3 de 3
      • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
      • There are 2 screws on the left side (when looking at the front of the camera).
      • There are 3 screws on the bottom
      • There is 1 screw on the right side
      Pregunta a FixBot
      Agregar Comentario
    2. Function Key Motherboard: paso 2, imagen 1 de 1
      • Turn to the bottom of the camera.
      • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
      Pregunta a FixBot
      Agregar Comentario
    3. Function Key Motherboard: paso 3, imagen 1 de 1
      • This is what the SD card/battery compartment looks like when opened.
      • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    4. Function Key Motherboard: paso 4, imagen 1 de 2 Function Key Motherboard: paso 4, imagen 2 de 2
      • Gently remove the front cover away from the camera body.
      • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
      Pregunta a FixBot
      Agregar Comentario
    5. Function Key Motherboard: paso 5, imagen 1 de 1
      • The camera should look like this once the front cover is removed.
      Pregunta a FixBot
      Agregar Comentario
    6. Function Key Motherboard: paso 6, imagen 1 de 3 Function Key Motherboard: paso 6, imagen 2 de 3 Function Key Motherboard: paso 6, imagen 3 de 3
      Herramienta utilizada en este paso:
      • Start from the battery compartment and remove the back cover.
      • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
      • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
      Pregunta a FixBot
      Agregar Comentario
    7. Function Key Motherboard: paso 7, imagen 1 de 1
      • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
      Pregunta a FixBot
      Agregar Comentario
    1. Function Key Motherboard, Function Key Motherboard: paso 8, imagen 1 de 3 Function Key Motherboard, Function Key Motherboard: paso 8, imagen 2 de 3 Function Key Motherboard, Function Key Motherboard: paso 8, imagen 3 de 3
      • Remove 2 4.35mm phillips head screws from around the LCD screen using a #00 phillips head screwdriver.
      • Caution: Do not tug on the LCD screen because this could tear the ribbon connecting the LCD screen to the body of the camera.
      • Loosen the black ribbon clamp using an iPod opening tool
      • Release the LCD screen by removing the ribbon from the body of the camera.
      Pregunta a FixBot
      Agregar Comentario
    2. Function Key Motherboard: paso 9, imagen 1 de 2 Function Key Motherboard: paso 9, imagen 2 de 2
      • Unscrew 2 3.35mm phillips head screw from the face of the function key motherboard using a #00 phillips head screwdriver.
      • Caution: Do not tug on the motherboard because this will tear the ribbon connecting the motherboard to the body of the camera.
      Pregunta a FixBot
      Agregar Comentario
    3. Function Key Motherboard: paso 10, imagen 1 de 3 Function Key Motherboard: paso 10, imagen 2 de 3 Function Key Motherboard: paso 10, imagen 3 de 3
      • Release the black ribbon clamp attached to the back of the motherboard using an iPod opening tool to lift the clamp.
      • Remove the ribbon connecting the function key motherboard from the body of the camera using tweezers.
      • The function key motherboard has the SD card reader attached to the back. The motherboard and SD card combination should be replaced.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 8-6, Regan Spring 2011 Miembro de Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
Miembros de 4
22 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 37
Todo El Tiempo: 3,784
