Introducción
Use this guide to replace the webcam, aka "webcam module," in your Framework 16" laptop.
Qué necesitas
Slide your fingernail under the inside edge of either bottom corner of the bezel.
Pull the bezel away from the screen to release the first few magnets.
Lift the bezel around the perimeter of the screen until all of its magnets are released.
Remove the bezel.
Use the flat end of a spudger, or a clean fingernail, to lift up the locking tab on the webcam module ZIF connector.
Use a T5 Torx screwdriver to remove the two 2 mm‑long screws securing the webcam module.
Use tweezers to lift the right side of the webcam module until the cable slides out of the ZIF connector.
Remove the webcam module.
Use tweezers to gently bend the webcam cable away from the screen frame.
Use your other hand to align the webcam module over the cable and lower it into place.
Make sure the webcam module sits level with the display before flipping down the cable locking tab and continuing reassembly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
