Introducción
Use this guide to replace the display in your Framework 16" laptop.
Qué necesitas
Slide your fingernail under the inside edge of either bottom corner of the bezel.
Pull the bezel away from the screen to release the first few magnets.
Lift the bezel around the perimeter of the screen until all of its magnets are released.
Remove the bezel.
Use a T5 Torx screwdriver to remove the four 2.4 mm‑long screws securing the display.
Grab the display and pull it straight off the screen frame to free it from its alignment pegs.
Flip the front of the display down and rest it on the keyboard.
Grip the display cable where it meets the connector head.
Slide the connector straight out of its socket to disconnect it.
Remove the display.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
