Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Finding Model Name
  1. Finding Model Name, Finding Model Name: paso 1, imagen 1 de 2 Finding Model Name, Finding Model Name: paso 1, imagen 2 de 2
    • Check the exterior of the laptop for a sticker with the model name on it. This sticker may be underneath the battery, or on the underside of the battery, so you have to remove the battery to see it.
    Pregunta a FixBot
    Agregar Comentario
    • Use the (Win+R) key combination to open the Run... dialog. Type "control panel" (with no quotation marks) into this box to open the control panel. Click "System and Security", then click "System". Look for a model name here.
    Pregunta a FixBot
    Agregar Comentario
    • DirectX diagnostic tool: Press (Win+R). The "Run" dialog will appear. Type “dxdiag” (with no quotes) into this box and click OK. The “DirectX Diagnostic Tool” window will appear. Click on the “System” page and look for a “System Model” entry.
    Pregunta a FixBot
    Agregar Comentario
    • Command prompt: Press (Win-R). The "Run" window should appear. Type “cmd” (with no quotes) into this box and click OK. Command Prompt should appear. Type the following into the Command Prompt window, but with no quotation marks: “wmic csproduct get name”. Press the enter key and your model name should appear.
    Pregunta a FixBot
    Agregar Comentario
    • Sometimes the model name is printed or labelled on the computer’s motherboard. It is beyond the scope of this guide to explain how to access the motherboard, but this guide may be helpful.
    Pregunta a FixBot
    Agregar Comentario
Linea de Meta
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 17
Ultimos 30 días: 42
Todo El Tiempo: 550
