Introducción
Use this guide to replace a damaged top unit in your Fairphone 5.
The top unit includes the time of flight sensor, the camera flash, and the SD and SIM card slots.
Qué necesitas
Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right of the back cover.
Pry up the back cover to release the bottom right corner clips.
Grip the bottom right corner of the back cover with one hand and brace the phone frame with the other.
Lift the back cover away from the phone to release the clips around its perimeter.
Remove the back cover.
Use your fingernail, or a pry tool like a spudger, to lift the battery by its tab along the bottom edge.
Remove the battery.
Use a Phillips driver to remove the 3.9 mm-long screw securing the top unit connector cover at the bottom left corner.
Insert your fingernail, or a pry tool like a spudger, under the notch at the left edge of the connector cover.
Pry up the cover to separate it from the top unit.
While holding the cover out of the way, use a spudger to pry up and disconnect the top unit press connector.
Use a Phillips driver to remove the six 4.9 mm‑long screws securing the top unit.
Insert the flat end of a spudger under the screw hole along the bottom edge of the top unit.
Pry up to release the clips securing the top unit to the phone frame.
