Introducción
Use this guide to replace the rear camera module in your Fairphone 3.
Qué necesitas
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
Pry the back cover up to start separating its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Lever the battery up until you can get a good grip.
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
17 personas más completaron esta guía.
3 comentarios
How NOT to remove the display!
I just destroyed my display module a bit and had to fix it with glue. :(
This works better: https://www.youtube.com/watch?v=wGTYZNzg...
I think this guide should mention that the camera connecting cable can become disconnected accidentally on its other end (under the metallic cover) which is easy to miss. This forum post helped me: https://forum.fairphone.com/t/be-careful...
The metallic cover can be removed easily after screwing off two Torx screws. Couple of people on the forum experienced this and it helped me solve my problem.
Pas de problème pour changer le module. Les explications données par ifixit sont claires et aisées à suivre.
