Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Factory Reset, Fix Android Problems with Sony PC Companion
Resumen del Video
  1. Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: paso 1, imagen 1 de 3 Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: paso 1, imagen 2 de 3 Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: paso 1, imagen 3 de 3
    Pregunta a FixBot
    Agregar Comentario
  2. Factory Reset, Fix Android Problems  with Sony PC Companion: paso 2, imagen 1 de 2 Factory Reset, Fix Android Problems  with Sony PC Companion: paso 2, imagen 2 de 2
    • Install Sony PC Companion in your PC.
    Pregunta a FixBot
    Agregar Comentario
  3. Factory Reset, Fix Android Problems  with Sony PC Companion: paso 3, imagen 1 de 3 Factory Reset, Fix Android Problems  with Sony PC Companion: paso 3, imagen 2 de 3 Factory Reset, Fix Android Problems  with Sony PC Companion: paso 3, imagen 3 de 3
    • Connect your laptop to power supply since the update of your phone will take some time.
    • Now choose "repair my phone / tablet". By this way you can fully erase your phone and remove any security password, PIN etc., or change firmware if your phone have OS problem and can't be powered on correctly.
    • This is your last warning about losing your personal data.
    Pregunta a FixBot
    Agregar Comentario
  4. Factory Reset, Fix Android Problems  with Sony PC Companion: paso 4, imagen 1 de 2 Factory Reset, Fix Android Problems  with Sony PC Companion: paso 4, imagen 2 de 2
    • PC Companion will download some files to prepare your PC for software update.
    • Your phone / tablet must be at last 80% for the update to proceed safely!
    Pregunta a FixBot
    Agregar Comentario
  5. Factory Reset, Fix Android Problems  with Sony PC Companion: paso 5, imagen 1 de 3 Factory Reset, Fix Android Problems  with Sony PC Companion: paso 5, imagen 2 de 3 Factory Reset, Fix Android Problems  with Sony PC Companion: paso 5, imagen 3 de 3
    • Select the model of your phone.
    • You should not confuse the model.
    Pregunta a FixBot
    Agregar Comentario
  6. Factory Reset, Fix Android Problems  with Sony PC Companion: paso 6, imagen 1 de 3 Factory Reset, Fix Android Problems  with Sony PC Companion: paso 6, imagen 2 de 3 Factory Reset, Fix Android Problems  with Sony PC Companion: paso 6, imagen 3 de 3
    • The USB cable must be connected only to the PC.
    • Turn off the phone.
    • Press and hold the Volume Down button while plugging the cable into your phone.
    • Once connected, PC Companion will download necessary firmware and will upload it to your phone.
    Pregunta a FixBot
    Agregar Comentario
  7. Factory Reset, Fix Android Problems  with Sony PC Companion: paso 7, imagen 1 de 3 Factory Reset, Fix Android Problems  with Sony PC Companion: paso 7, imagen 2 de 3 Factory Reset, Fix Android Problems  with Sony PC Companion: paso 7, imagen 3 de 3
    • Your PC must recognize your phone like SOMC Flash Device.
    • If you have a problem with drivers (your PC can't recognize your phone), search in the internet for "S1Boot Fastboot" drivers or use the link below.
    • '''Android WinUSB drivers'''
    Pregunta a FixBot
    Agregar Comentario
  8. Factory Reset, Fix Android Problems  with Sony PC Companion: paso 8, imagen 1 de 3 Factory Reset, Fix Android Problems  with Sony PC Companion: paso 8, imagen 2 de 3 Factory Reset, Fix Android Problems  with Sony PC Companion: paso 8, imagen 3 de 3
    • When PC Companion finished with update process, disconnect the phone and switch it on.
    • Now your phone is in factory condition, with erased custom data and without password protection.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
    Pregunta a FixBot
    Agregar Comentario
Conclusión
114 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
197,225 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
Miembros de 333
1,496 Guías creadas
26Guía Comentarios
thanks so much. btw if it says you should unlock first, just press emergency calls and it accepts it
Godstime Osarobo - Contestar Compartir
really???????
Aiman Farizi Amaanullah - Contestar Compartir
my xperia ( LT22i ) is not listed
abdul azeem - Contestar Compartir
there is an error every time i try to use pc companion
error code: uegetphoneinfofailure
leo leo - Contestar Compartir
there are an error
I can't download the upgrade on my phone
arnold - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 26
Ultimos 30 días: 142
Todo El Tiempo: 235,259
