Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
ExoPC Slate Camera Replacement
Qué necesitas
    1. ExoPC Slate Camera Replacement, Camera: paso 1, imagen 1 de 1
      • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
      Pregunta a FixBot
      Agregar Comentario
    2. ExoPC Slate Camera Replacement: paso 2, imagen 1 de 1
      • Using the 00 Phillips screwdriver remove the two screws in the corners.
      • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
      • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
      Pregunta a FixBot
      Agregar Comentario
    3. ExoPC Slate Camera Replacement: paso 3, imagen 1 de 1
      • Remove the tape covering the metal shield.
      • Remove the 12 screws using the Phillips #00 screwdriver.
      • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
      Pregunta a FixBot
      Agregar Comentario
    4. ExoPC Slate Camera Replacement: paso 4, imagen 1 de 2 ExoPC Slate Camera Replacement: paso 4, imagen 2 de 2
      Herramienta utilizada en este paso:
      • Use tweezers to disconnect camera cable from motherboard.
      • Remove the Phillips #000 screw that holds the camera in place.
      • Gently remove the camera.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Aaron Moore
Miembro Desde 10/30/18
217 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team S2-G1, Peak Fall 2018 Miembro de UMass Dartmouth, Team S2-G1, Peak Fall 2018
UMASSD-PEAK-F18S2G1
Miembros de 3
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 44
Todo El Tiempo: 544
