Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Ematic Genesis Screen Replacement
Qué necesitas
    1. Ematic Genesis Screen Replacement, Ematic Genesis Casing: paso 1, imagen 1 de 3 Ematic Genesis Screen Replacement, Ematic Genesis Casing: paso 1, imagen 2 de 3 Ematic Genesis Screen Replacement, Ematic Genesis Casing: paso 1, imagen 3 de 3
      • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
      Pregunta a FixBot
      Agregar Comentario
    2. Ematic Genesis Screen Replacement: paso 2, imagen 1 de 3 Ematic Genesis Screen Replacement: paso 2, imagen 2 de 3 Ematic Genesis Screen Replacement: paso 2, imagen 3 de 3
      • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
      • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
      • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
      • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
      Pregunta a FixBot
      Agregar Comentario
    3. Ematic Genesis Screen Replacement: paso 3, imagen 1 de 1
      • Remove back plate from screen plate and lay both down flat next to each other.
      Pregunta a FixBot
      Agregar Comentario
    1. Ematic Genesis Screen Replacement, Battery: paso 4, imagen 1 de 3 Ematic Genesis Screen Replacement, Battery: paso 4, imagen 2 de 3 Ematic Genesis Screen Replacement, Battery: paso 4, imagen 3 de 3
      • Lift up the two pieces of tape holding the copper plate and the connector ribbon to the battery. Gently hold or place away from the battery.
      Pregunta a FixBot
      Agregar Comentario
    2. Ematic Genesis Screen Replacement: paso 5, imagen 1 de 3 Ematic Genesis Screen Replacement: paso 5, imagen 2 de 3 Ematic Genesis Screen Replacement: paso 5, imagen 3 de 3
      Herramienta utilizada en este paso:
      Plastic Cards
      $2.99
      • Using a plastic card, gently break the adhesive that holds the battery to the metal screen plate.
      • The battery is very bendable. Although it may not be working, there are still dangerous contents inside batteries.
      Pregunta a FixBot
      Agregar Comentario
    3. Ematic Genesis Screen Replacement: paso 6, imagen 1 de 1
      • If replacing the battery, disconnect the wires that connect the battery to the motherboard.
      • If not replacing the battery, do NOT disconnect the wires.
      • To reconnect the new battery, a soldering kit will be necessary. Use the iFixit soldering guide to gain further information on how to complete this step.
      • Cómo soldar y desoldar conexiones
      Pregunta a FixBot
      Agregar Comentario
    1. Ematic Genesis Screen Replacement, Camera: paso 7, imagen 1 de 2 Ematic Genesis Screen Replacement, Camera: paso 7, imagen 2 de 2
      • Once the panels are separated, remove the tape holding down the ribbon connector that is connecting the camera to the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    2. Ematic Genesis Screen Replacement: paso 8, imagen 1 de 2 Ematic Genesis Screen Replacement: paso 8, imagen 2 de 2
      • Lift up the black lever of the connector that holds the camera ribbon in place.
      Pregunta a FixBot
      Agregar Comentario
    3. Ematic Genesis Screen Replacement: paso 9, imagen 1 de 2 Ematic Genesis Screen Replacement: paso 9, imagen 2 de 2
      • Gently pull the ribbon out of the connector and lift the camera out of the casing.
      • There is adhesive holding the camera in the case. Pull up strong enough to separate the camera from the casing without damaging the components.
      Pregunta a FixBot
      Agregar Comentario
    1. Ematic Genesis Screen Replacement, Button: paso 10, imagen 1 de 3 Ematic Genesis Screen Replacement, Button: paso 10, imagen 2 de 3 Ematic Genesis Screen Replacement, Button: paso 10, imagen 3 de 3
      • Once battery is removed, flip up the black lever of the connector that is holding the wide ribbon in place for the screen. Remove the ribbon from the connector.
      Pregunta a FixBot
      Agregar Comentario
    2. Ematic Genesis Screen Replacement: paso 11, imagen 1 de 3 Ematic Genesis Screen Replacement: paso 11, imagen 2 de 3 Ematic Genesis Screen Replacement: paso 11, imagen 3 de 3
      • Rotate the tablet 180 degrees and flip up the black lever of the connector holding the small, yellow ribbon. Remove ribbon from the connector.
      Pregunta a FixBot
      Agregar Comentario
    3. Ematic Genesis Screen Replacement: paso 12, imagen 1 de 3 Ematic Genesis Screen Replacement: paso 12, imagen 2 de 3 Ematic Genesis Screen Replacement: paso 12, imagen 3 de 3
      • Rotate the tablet 90 degrees and remove the three (3) 1.3 mm Phillips #00 screws that hold the motherboard in place.
      Pregunta a FixBot
      Agregar Comentario
    4. Ematic Genesis Screen Replacement: paso 13, imagen 1 de 2 Ematic Genesis Screen Replacement: paso 13, imagen 2 de 2
      • Lift up the tape that covers the speaker wires and holds the motherboard in place.
      • This picture does not show speaker wires attached. These do NOT have to be disconnected for this.
      • Be careful not to disconnect the speaker wires from the motherboard. Otherwise, they will need to be soldered back on.
      Pregunta a FixBot
      Agregar Comentario
    5. Ematic Genesis Screen Replacement: paso 14, imagen 1 de 2 Ematic Genesis Screen Replacement: paso 14, imagen 2 de 2
      • With the motherboard detached from the screen plate, there is now access to the electrical components under the motherboard and the mechanical button components on the back plate.
      Pregunta a FixBot
      Agregar Comentario
    1. Ematic Genesis Screen Replacement, Screen: paso 15, imagen 1 de 2 Ematic Genesis Screen Replacement, Screen: paso 15, imagen 2 de 2
      • Once the battery and motherboard have been removed, gently bend the screen plate to pop out the metal digitizer that sits on the glass and plastic screen.
      • Be careful when bending as glass could break.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Baylor, Team 4-3, Williams Spring 2015 Miembro de Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
Miembros de 3
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 27
Todo El Tiempo: 1,478
