Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Ematic Genesis Camera Replacement
Qué necesitas
  1. Ematic Genesis Camera Replacement, Ematic Genesis Casing: paso 1, imagen 1 de 3 Ematic Genesis Camera Replacement, Ematic Genesis Casing: paso 1, imagen 2 de 3 Ematic Genesis Camera Replacement, Ematic Genesis Casing: paso 1, imagen 3 de 3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
    Pregunta a FixBot
    Agregar Comentario
  2. Ematic Genesis Camera Replacement: paso 2, imagen 1 de 3 Ematic Genesis Camera Replacement: paso 2, imagen 2 de 3 Ematic Genesis Camera Replacement: paso 2, imagen 3 de 3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
    Pregunta a FixBot
    Agregar Comentario
  3. Ematic Genesis Camera Replacement: paso 3, imagen 1 de 1
    • Remove back plate from screen plate and lay both down flat next to each other.
    Pregunta a FixBot
    Agregar Comentario
  4. Ematic Genesis Camera Replacement, Camera: paso 4, imagen 1 de 2 Ematic Genesis Camera Replacement, Camera: paso 4, imagen 2 de 2
    • Once the panels are separated, remove the tape holding down the ribbon connector that is connecting the camera to the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  5. Ematic Genesis Camera Replacement: paso 5, imagen 1 de 2 Ematic Genesis Camera Replacement: paso 5, imagen 2 de 2
    • Lift up the black lever of the connector that holds the camera ribbon in place.
    Pregunta a FixBot
    Agregar Comentario
  6. Ematic Genesis Camera Replacement: paso 6, imagen 1 de 2 Ematic Genesis Camera Replacement: paso 6, imagen 2 de 2
    • Gently pull the ribbon out of the connector and lift the camera out of the casing.
    • There is adhesive holding the camera in the case. Pull up strong enough to separate the camera from the casing without damaging the components.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Equipo
Baylor, Team 4-3, Williams Spring 2015 Miembro de Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
Miembros de 3
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 42
Todo El Tiempo: 442
