Introducción
It is a little tricky to set the ECAM models with touch display to test mode. These instructions show you how to do this. You can use the test mode to quickly check the function of the most important components. For models with "real" buttons, see here.
When the machine is switched on, press the off-switch until the machine goes into standby mode and the display turns off.
There has to be water in the water tank, the drip tray is initially still inserted. The power plug remains in the outlet.
Work through the steps in reverse order to reassemble your device.
3 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ oldturkey03 nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
