Saltar al contenido principal
DualSense Edge Joysticks Replacement
Qué necesitas
  1. DualSense Edge Joysticks Replacement, Remove the front trim: paso 1, imagen 1 de 3 DualSense Edge Joysticks Replacement, Remove the front trim: paso 1, imagen 2 de 3 DualSense Edge Joysticks Replacement, Remove the front trim: paso 1, imagen 3 de 3
    • Place the controller on a work surface with the joysticks facing down.
    • Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
    • If the front trim doesn't fall open, make sure the front trim has room to fall down and the Release tab is pushed all the way to the left.
    • Lift the controller up, leaving the front trim on the table.
    • During reassembly, insert the front trim at an angle so the top slots in first, then lower the trim into place and snap it onto the controller.
  2. DualSense Edge Joysticks Replacement, Remove the joysticks: paso 2, imagen 1 de 3 DualSense Edge Joysticks Replacement, Remove the joysticks: paso 2, imagen 2 de 3 DualSense Edge Joysticks Replacement, Remove the joysticks: paso 2, imagen 3 de 3
    • Flip the controller over so the joysticks are facing up.
    • Lift the metal lever that holds the joystick in place until the joystick slides out slightly.
    • Slide the joystick out from its slot.
  3. DualSense Edge Joysticks Replacement: paso 3, imagen 1 de 1
    • Repeat this process to remove the other joystick.
Conclusión
Spencer Pennington
Miembro Desde 09/09/23
17,049 Reputación
113 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,455 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 21
Ultimos 7 días: 226
Ultimos 30 días: 607
Todo El Tiempo: 3,191
