Introducción
This is a prerequisite-only guide for disconnecting the battery on a Samsung Galaxy Note9! This guide is part of another procedure and is not meant to be used alone.
Power off your phone before beginning disassembly.
Use a hairdryer, a heatgun, or prepare an iOpener and apply it to the right edge of the back of the phone for about a minute to soften the adhesive underneath.
Apply a suction handle to the back cover.
Lift with a suction handle to create a gap between the back cover and the frame of the phone.
Insert an opening pick into the gap.
Note that there is more adhesive along the top edge and around the camera bezel than around the rest of the phone.
Cut carefully around the left edge near the fingerprint sensor or you risk damaging the ribbon cable inside.
Starting from the center, cut the adhesive up and down the right side with an opening pick.
Use the tip of a spudger to pry the fingerprint sensor ribbon cable up and out of its socket.
Remove the back cover.
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Carefully apply the new adhesive to the back cover, then line up one edge of the glass against the phone chassis and firmly press the glass into the phone.
Use a Phillips screwdriver to remove the nine 4 mm screws securing the upper midframe.
Use the tip of a spudger to disconnect the orange ribbon cable connecting the battery to the motherboard.
