Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu iClicker, utiliza nuestros manuales de servicio .
    1. Disassembling iClicker Device, Disassembling iClicker Device: paso 1, imagen 1 de 1
      • Behold the iclicker in all its interactive and educational beauty.
      Pregunta a FixBot
      Agregar Comentario
    2. Disassembling iClicker Device: paso 2, imagen 1 de 1
      • Place the device on a flat surface, buttons facing down.
      • Remove the battery cover and the three batteries within.
      Pregunta a FixBot
      Agregar Comentario
    3. Disassembling iClicker Device: paso 3, imagen 1 de 2 Disassembling iClicker Device: paso 3, imagen 2 de 2
      • Remove the two visible screws using a #00 Phillips screwdriver.
      • Oops! Don't forget a hidden third screw beneath the factory label.
      • Peel back the corner of the label to reveal the hidden screw.
      • If you wish to maintain the integrity of the label, a blowdryer may be used to soften the adhesive on the label before removal.
      Pregunta a FixBot
      Agregar Comentario
    4. Disassembling iClicker Device: paso 4, imagen 1 de 2 Disassembling iClicker Device: paso 4, imagen 2 de 2
      • Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers.
      • For the more resistent iclickers, a spudger may be employed to separate the pieces.
      Pregunta a FixBot
      Agregar Comentario
    5. Disassembling iClicker Device: paso 5, imagen 1 de 1
      • Your iclicker is now exposed for all its worth.
      • The back panel can be set aisde, as the remaining components are housed in the front panel.
      Pregunta a FixBot
      Agregar Comentario
    6. Disassembling iClicker Device: paso 6, imagen 1 de 2 Disassembling iClicker Device: paso 6, imagen 2 de 2
      • Using a spudger, gently pry the battery connectors from the front panel.
      Pregunta a FixBot
      Agregar Comentario
    7. Disassembling iClicker Device: paso 7, imagen 1 de 1
      • If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
      Pregunta a FixBot
      Agregar Comentario
    8. Disassembling iClicker Device: paso 8, imagen 1 de 1
      • The buttons can be easily removed from the front assembly sans spudger.
      Pregunta a FixBot
      Agregar Comentario
    9. Disassembling iClicker Device: paso 9, imagen 1 de 1
      • Don't lose the small LED cover sitting precariously in the front panel.
      Pregunta a FixBot
      Agregar Comentario
    10. Disassembling iClicker Device: paso 10, imagen 1 de 1
      • Your iclicker is now disassembled.
      Pregunta a FixBot
      Agregar Comentario
1Guía Comentario
What is an iClicker ?
furbies - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 28
Todo El Tiempo: 8,215
