Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Disassembling Nokia 3395 Screen
Qué necesitas
  1. Disassembling Nokia 3395 Screen, Back Case: paso 1, imagen 1 de 3 Disassembling Nokia 3395 Screen, Back Case: paso 1, imagen 2 de 3 Disassembling Nokia 3395 Screen, Back Case: paso 1, imagen 3 de 3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
    Pregunta a FixBot
    Agregar Comentario
  2. Disassembling Nokia 3395 Screen, Battery: paso 2, imagen 1 de 2 Disassembling Nokia 3395 Screen, Battery: paso 2, imagen 2 de 2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
    Pregunta a FixBot
    Agregar Comentario
  3. Disassembling Nokia 3395 Screen, Front Case: paso 3, imagen 1 de 2 Disassembling Nokia 3395 Screen, Front Case: paso 3, imagen 2 de 2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
    Pregunta a FixBot
    Agregar Comentario
  4. Disassembling Nokia 3395 Screen, Screen: paso 4, imagen 1 de 2 Disassembling Nokia 3395 Screen, Screen: paso 4, imagen 2 de 2
    • Remove six T6 screws.
    Pregunta a FixBot
    Agregar Comentario
  5. Disassembling Nokia 3395 Screen: paso 5, imagen 1 de 2 Disassembling Nokia 3395 Screen: paso 5, imagen 2 de 2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Nico Lee
Miembro Desde 04/19/10
83 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 30-41, Garner Spring 2010 Miembro de Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
Miembros de 4
11 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 46
Todo El Tiempo: 2,830
