Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Disassembling APEX AP-GS918 Screen
Qué necesitas
  1. Disassembling APEX AP-GS918 Screen, Power/Volume Button: paso 1, imagen 1 de 3 Disassembling APEX AP-GS918 Screen, Power/Volume Button: paso 1, imagen 2 de 3 Disassembling APEX AP-GS918 Screen, Power/Volume Button: paso 1, imagen 3 de 3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
    Pregunta a FixBot
    Agregar Comentario
  2. Disassembling APEX AP-GS918 Screen: paso 2, imagen 1 de 3 Disassembling APEX AP-GS918 Screen: paso 2, imagen 2 de 3 Disassembling APEX AP-GS918 Screen: paso 2, imagen 3 de 3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
    Pregunta a FixBot
    Agregar Comentario
  3. Disassembling APEX AP-GS918 Screen: paso 3, imagen 1 de 2 Disassembling APEX AP-GS918 Screen: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
    Pregunta a FixBot
    Agregar Comentario
  4. Disassembling APEX AP-GS918 Screen, Battery: paso 4, imagen 1 de 2 Disassembling APEX AP-GS918 Screen, Battery: paso 4, imagen 2 de 2
    • Begin removing the black tape covering the motherboard inside the tablet.
    Pregunta a FixBot
    Agregar Comentario
  5. Disassembling APEX AP-GS918 Screen: paso 5, imagen 1 de 1
    • You will need to desolder the two contact points that connect the battery to the mother board.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
    Pregunta a FixBot
    Agregar Comentario
  6. Disassembling APEX AP-GS918 Screen: paso 6, imagen 1 de 2 Disassembling APEX AP-GS918 Screen: paso 6, imagen 2 de 2
    • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
    • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
    Pregunta a FixBot
    Agregar Comentario
  7. Disassembling APEX AP-GS918 Screen, Screen: paso 7, imagen 1 de 2 Disassembling APEX AP-GS918 Screen, Screen: paso 7, imagen 2 de 2
    • The motherboard will need to be removed in order to access the screen.
    • To remove the motherboard you must first unscrew four 4.9mm Phillips #00 screws.
    Pregunta a FixBot
    Agregar Comentario
  8. Disassembling APEX AP-GS918 Screen: paso 8, imagen 1 de 2 Disassembling APEX AP-GS918 Screen: paso 8, imagen 2 de 2
    • To finish removing the motherboard you must release the two data cables holding the screen to it.
    • Use the black nylon spudger to lift the gray clips up 90° on the white connectors.
    • You can now remove the data cables from the slots and lift the motherboard out from the device.
    Pregunta a FixBot
    Agregar Comentario
  9. Disassembling APEX AP-GS918 Screen: paso 9, imagen 1 de 2 Disassembling APEX AP-GS918 Screen: paso 9, imagen 2 de 2
    • After removing the motherboard, use the black nylon spudger to pop the screen out of the housing holding it to the front of the screen case.
    Pregunta a FixBot
    Agregar Comentario
  10. Disassembling APEX AP-GS918 Screen: paso 10, imagen 1 de 1
    • Pull the thin plastic screen casing apart and you can remove the damaged screen.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 9-1, Leahy Winter 2015 Miembro de USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
Miembros de 3
9 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 43
Todo El Tiempo: 979
